Chase Bays cm1 b series harness problems
Old 11-30-2015, 02:26 PM
EGeezy's Avatar
Default Chase Bays cm1 b series harness problems
Hey guys and ladys I have a 98 jdm type r in a EG 92 civic.
Hooked all the engine harness up and spliced the green with yellow stripe wire into the old A7 ecu thinking this is the fuel pump relay. It turns over but is not sending fuel to the injectors? Also its turning over in the 2nd key position instead of the 3rd key position? That should not happen! my main concern is I live in Minnesota its starting to snow and my elderly mom has to park her truck in the garage cuz my whips been in there since last Sept. If anyone knows of these problems would you please help me figure it out. I've read one thread that has had similar problems but ended without an answer. again I need to know what the 3 wires one solid brown, one orange with blue stripe and one green with yellow stripe get spliced into what ? wire on my old ecu plugs.
Thanks in advance!!!
Dave
Old 11-30-2015, 02:36 PM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: Chase Bays cm1 b series harness problems
That old thread you found (and necrobumped) did have a resolution. The harness was made wrong, and customer service was functionally useless. Call Chasebays, and get them to fix the problem for you, or return it and get a harness from a company that isn't going to screw you over.
Old 12-01-2015, 02:59 PM
Technical Hero
HondaPartsHero's Avatar
Yep call them or contact them. If a company doesn't have support after the fact they're not worth dealing with in the first place.
b20vteg757
11-06-2013 06:16 PM
fastraver
03-30-2013 02:37 PM
541Motorsports
05-12-2012 02:25 AM
eg6madness
03-08-2011 04:16 PM
Quick Reply: Chase Bays cm1 b series harness problems
