A/C intermittent problem
Old 01-17-2011, 10:30 AM
DAP97SI's Avatar
Default A/C intermittent problem
I have search but could not find anything that relates to my specific problem. I have a 97 Civic Hatchback. I have never touched or messed with any of the A/C components. I started having issues with my A/C, when I turn it on sometimes it will not come on at all, but if I tap or bang under the passenger side dash it will kick in. I am thinking something might be loose or one of the components is going bad. When the A/C kicks in, it works fine, no problems, the problem is trying to get it to kick in. Any help would be very appreciated.
DAP97SI is offline
Old 01-17-2011, 10:34 AM
Former User's Avatar
Default Re: A/C intermittent problem
When the A/C does NOT work:
1) Does the A/C button light illuminate when the button is pressed?
2) Does the A/C condenser fan run when the button is pressed?
3) Does the A/C compressor clutch engage when the button is pressed?
Former User is offline
Old 01-17-2011, 11:56 AM
DAP97SI's Avatar
1) Yes it does.
2) nothing happens
3) not sure what you mean.
When I turn it on, it will not blow.
DAP97SI is offline
Old 01-17-2011, 12:08 PM
Originally Posted by DAP97SI
1) Yes it does.
2) nothing happens
So the problem is that the blower motor won't run rather than an A/C problem?
Old 01-17-2011, 12:18 PM
MonkeyMagic's Avatar
so air doesn't come out of the vents some times unless you slap the pasenger side under the dash?
time for a new blower motor
MonkeyMagic is offline
Old 01-17-2011, 12:19 PM
DAP97SI's Avatar
correct. so I need a new blower motor?
DAP97SI is offline
Old 01-17-2011, 12:22 PM
thats what it sounds like. does it not work on any of the fan settings?
typically when electric motors die, you can slap them and they'll run for a little bit or untill turned off, or maybe just a turn or two.
if you look under the dash behind the glove box, you'll see a round lid-looking piece and that is the top of the blower motor. one electric plug and i think three bolts hold it up there.
Old 01-17-2011, 12:26 PM
Run power and ground wires directly from the battery to the blower motor. Does the motor run fine or does it only run intermittently?
Old 01-17-2011, 01:00 PM
DAP97SI's Avatar
It runs fine once it kicks in, no problems.
DAP97SI is offline
Old 01-17-2011, 02:20 PM
Are you saying that you did the test I suggested and the blower motor always works when its connected to the power and ground wires?
Old 01-17-2011, 03:03 PM
DAP97SI's Avatar
No, I don't have the means to do that right now. What I am saying is that whenever it kicks in I don't have any problems, it won't shut off or stop blowing or anything like that. The problem I have is that sometimes it takes a slap to make it kick in.
DAP97SI is offline
Old 01-18-2011, 09:11 AM
Cynical 1's Avatar
run ron's test and report back.
Cynical 1 is offline
Old 06-18-2014, 12:34 AM
Splatch's Avatar
It is the AC relay in the underhood fuse panel. There are 3 in my Accord. 2 for AC and 1 for radiator.
Just swap out the relays to see if the problem goes away; if it does fix problem, put relays back in original order and go to partsgeek and order the replacement relay. $7
Splatch is offline
Old 06-18-2014, 03:53 AM
Old thread closed.
mjsotelo91
07-24-2011 06:34 AM
johnone
08-15-2010 12:48 AM
Blueblotch
07-05-2007 07:30 PM
My95SlvrBlt
08-08-2006 04:53 AM
Quick Reply: A/C intermittent problem
