changing D16Z6 head gasket, have a quick question for youse guys.
besides the intake and exhaust mani gaskets and the head gasket(duh), what other gaskets/things should I be replacing? I'm replacing the waterpump, thermostat, timing belt/tensioner and the valve seals already, but I know I'm missing something. It's going to be a long weekend job with beer involved, so hook a brother up, yO! Thanks!
Re: changing D16Z6 head gasket, have a quick question for youse guys. (95civexjet)
Don't forget the valve cover gasket, and throw in a new set of spark plug seals
Re: changing D16Z6 head gasket, have a quick question for youse guys. (Ignitecivic)
Why change all those gaskets?
T/B isn't required unless your taking it off, it's not like it's going to go bad.
If your pulling the head off then the head gasket and vlave cover along with plug seals is a good recomendation but why the IM gasket if your not removing the IM?
it's not like those gaskets just wear out there isn't anything that would cause them to wear prematurly. Just my .02 cents
Re: changing D16Z6 head gasket, have a quick question for youse guys. (BauleyCivic)
exhaust gasket also. replace hoses and oil and filter while your at it.
$0.02
$0.02
Re: changing D16Z6 head gasket, have a quick question for youse guys. (NA_95d16z6)
I KNEW I was missing something. thanks, you guys kick ***. Hopefully nothing will need to go to the the shop and it won't crap out before next weekend . thanks again.
jodyboy
12-30-2012 04:43 AM
Rikaro
02-28-2008 10:07 AM
change, cover, d16z6, exhaust, gasket, grommets, head, headgasket, modify, replacement, replacing, valve, valvecover
