changed tire size/my speedo isnt reading correct ?
i just put a set of 17" racinghart cp-10 wheels with 215/45 tires on my del sol. ive seen one before, but does anyone know where i can find a chart where it shows the speed the speedo says compared to your actual speed? thanks alot
Re: changed tire size/my speedo isnt reading correct ? (SolBreak)
http://www.f-body.org/gears/
https://honda-tech.com/zerothread?id=629535
should help you out a bit, just need to find the gearing of your tranny.
Darth ModerVader
http://www.miata.net/garage/tirecalc.html
I would strongly suggest purchasing tires of the correct size for your application, which your current ones clearly are not.
Re: changed tire size/my speedo isnt reading correct ? (Padawan)
