Changed Fuel Injectors=Check Engine Light
Changed Fuel Injectors=Check Engine Light? Please help diagnose!
Ok its 12am, and I just changed my fuel injectors. Everything was fine....started car up...fine....cruised a few seconds...fine...Got on the gas, at about 3500 the engine seemed to have cut back and then my check engine light came on. Anyone have any idea what could be wrong?
[Modified by EG CoUpe, 12:20 AM 3/9/2003]
Re: Changed Fuel Injectors=Check Engine Light (EG CoUpe)
Hey there...welcome to H-T. FYI, you need to provide more info to us when u want us to diagnose a problem. What fuel injectors did you switch from...did you swap them in in-place of the stock injectors?? Did you tighten everything down properly...good luck and explain always in the future.
EDIT: Yaaa....what Kamin said too, bitch
[Modified by GTlvr82, 3:23 AM 3/9/2003]
Re: Changed Fuel Injectors=Check Engine Light? Please help diagnose! (EG CoUpe)
Im not too sure how to check the codes but its a d15b7....someone told me its possible to put in b16 injectors.... everything is tightened/hooked up fine.
y am i a bitch?
[Modified by EG CoUpe, 12:28 AM 3/9/2003]
y am i a bitch?
y am i a bitch?
I'm not trying to be mean...it just seems like you won't tell us what you are trying to do with the injectors (what is your purpose) and it might be something as stupid as low fuel pressure because you didn't tighten the **** down and it's leaking somewhere...I have seen it happen
Re: Changed Fuel Injectors=Check Engine Light? Please help diagnose! (GTlvr82)
ok bro....ive just got the OE injectors...so i figured newer ones (b16) would give me better fuel pressure. yes I too am awaiting a swap. H22 in the near future. but do you know why the check engine light keeps turning on?
harryr34
06-07-2005 01:23 PM
xcathodex
03-20-2003 07:44 AM
