Changed axle, then got an alignment. Now car pulls hard right.
I have an EG with an omni coilover suspension on it & totally stock engine. Before i replaced the axle the car drove perfectly straight.
About a week ago i replaced the right axle because the cv boot was torn. I replaced it with one from autozone. I only replaced the right side, as the left side is fine.
I followed the helms manual step by step through the process & torqued every bolt down to factory spec.
After finishing i go for a drive to make sure all is well. The axle worked out great. But i do notice that the car now pulls right. I figure it was because of replacing the axle.
So i go get an alignment. The guy zero's the toe out. I leave & it still pulls to the right exactly the same as before.
When i throw the car in neutral it will coast perfectly straight. However, when i'm giving it and i give it gas, it pulls right. The more i get on the gas, the harder it pulls right.
I rechecked every bolt, bushing, & ball joint & all is well. Also checked the tire pressures.
Could using a new axle on one side & an old one on the other side cause this? Or what else could it be? Thanks
drjondurst
55
02-13-2003 09:38 AM
