cf hood does not fit good.....
i got a cf hood for 300 brand new. still in the box and wrapped up in bubble wrap. i tried putting it on but the hood is shifted toward the passenger side and rubbing the fender. is there anything i can do that will fix this?
Re: cf hood does not fit good..... (sting94112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sting94112 »</TD></TR><TR><TD CLASS="quote">i got a cf hood for 300 brand new. still in the box and wrapped up in bubble wrap. i tried putting it on but the hood is shifted toward the passenger side and rubbing the fender. is there anything i can do that will fix this?</TD></TR></TABLE>
yeah loosen the hood bolts and push the hood towards the drivers side and do this untill perfect.
Re: cf hood does not fit good..... (whoDAT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whoDAT »</TD></TR><TR><TD CLASS="quote">what brand did you get?</TD></TR></TABLE>
i dont know the brand. all i know is that it is a o.e style hood.
Re: (D16z6Coupe)
i had alot of fitment issues with my shitty cf hood. after playing with it enough i just traded some one for there stock straight up (mine was damaged in a wreck). i am much happier with the stock now
good luck
good luck
Re: cf hood does not fit good..... (Turbo92cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo92cx »</TD></TR><TR><TD CLASS="quote">
yeah loosen the hood bolts and push the hood towards the drivers side and do this untill perfect. </TD></TR></TABLE>u mean the four bolts that holds the hood up? it doesnt go anymore toward the driver side. i think the predrilled holes are not in the right spot. will a body shop know how to put it on?
Re: (D16z6Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16z6Coupe »</TD></TR><TR><TD CLASS="quote">Adjust the rubber things on the front screw then down more till u even both side</TD></TR></TABLE> where is this rubber thing located?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sting94112 »</TD></TR><TR><TD CLASS="quote">u mean the four bolts that holds the hood up? it doesnt go anymore toward the driver side. i think the predrilled holes are not in the right spot. will a body shop know how to put it on?</TD></TR></TABLE>
Dude. Try loosening the four bolts and follow what he said. The hinges are independent of each other and as you pull the hood in the direction it needs to go tighten the bolts. This will slowly work your hood over.
You can play with the rubber stops to adjust the front corner levels. You may even need to loosen a couple of fender bolts to get proper gap fitting up the sides of the hood and fenders.
This is Real Easy. You Can Do It!
Re: cf hood does not fit good..... (RangerDan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RangerDan »</TD></TR><TR><TD CLASS="quote">
This is Real Easy. You Can Do It!</TD></TR></TABLE>
before you loosen the fenders, try bending the hood hinges to whatever side. then screw on the hood and see.
Re: cf hood does not fit good..... (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">shti happens when u buy an Aftermarket house</TD></TR></TABLE>Say what?
damn i know i should have bought a OEM house in the first place.
what was i thinking!!
