cf duckbill
Re: cf duckbill (thashiz21)
Depends on the brand. Some have threaded holes that require you to use a bolt, while others have bolts already embedded that allow you to use the factory nuts.
Re: (deadline)
do you know if I could just buy the bolts at a local hardware store or if are they some odd kind of bolt that I would need to order through the company that made the duckbill
I just put mine on the other day. I got it from Jdmshit.com and it came with other bolts. The bolts are a bitch to line up, but I got it on with flawless clearence.
Re: (SPNFEDEH)
well i'm planning on buying one from this guy who is "selling it for his friend" and it doesn't have any of the bolts with it.....sounds kinda fishy to me. but anywho, just trying to make sure that i dont get stuck with not being able to mount it if i cant get the right bolts.
Re: (thashiz21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thashiz21 »</TD></TR><TR><TD CLASS="quote">well i'm planning on buying one from this guy who is "selling it for his friend" and it doesn't have any of the bolts with it.....sounds kinda fishy to me. but anywho, just trying to make sure that i dont get stuck with not being able to mount it if i cant get the right bolts.</TD></TR></TABLE>
Just look at it before you buy it, as long as there's studs or it's tapped for a bolt, you can find a replacement at Home Depot, or somewhere similar.
Re: (sillylilcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sillylilcivic »</TD></TR><TR><TD CLASS="quote">damn, that is hideous</TD></TR></TABLE>
You are probably alone on that thought.
Oil pan bolts work. Its a very common honda bolt size, I probably have a bunch in my hardware box. Just go to the dealer and order em if you don't know how to get the right sized and thread pitch bolts, their like 20 cents each.
Re: (sillylilcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sillylilcivic »</TD></TR><TR><TD CLASS="quote">thats fine with me, ill be the guy laughing and pointing at you after i pass.</TD></TR></TABLE>
Look at me, i'm swingin my dick around.
After you pass my daily driver civic? ok... big man, biiiig man!
Re: (sillylilcivic)
You're not acting like you're 25. I'd guess 15 tops.
If you aren't going to contribute to the thread, don't reply.
aimbot
08-13-2008 04:14 PM
