CEL #41 and 80. d16y5 97 hx
CEL #41 Primary Oxygen sensor heater.
I got 2 CELs, one was 41 Primary oxygen sensor heater and second 80 EGR Valve/Line. This is a 97 civic hx d16y5 with over 200k. runs good but will run better if i fix both.
I have stock header to straight pipe welded to a aftermarket exhaust. its throwing code for 41 Primary oxygen sensor heater, that would be on the actual test pipe if i had one? so due to not getting stock piping or a test pipe, how can i fix this problem? do i need to cut a hole and buy a o2 sensor?
The egr problem should be fixed today or tomorrow. todays weather is actually nice and might go in and clean the ports.
Re: CEL #41 and 80. d16y5 97 hx
bump! anyone know an idea they can share with the o2 problem? and i'm not really wanting to conver to obd1.
blkcivic99_03
06-11-2009 11:05 PM
