carbon kevlar sunroof done (pics) ...... 56k NoNoNoNoNoNo
finally warmed up and I took some pics of the first one we made , construction is two layer carbon fiber with a center layer of kevlar , these will be available in a few weeks but they are hand made so its normally a one week turnaround.
it rivets around the perimeter of the open roof when you pull the sunroof out , I ran a bead of black silicone around mine to seal it up but it fits so tight it might not even be needed.
total weight is less than one lb , the sunroof weighs somewhere around 40lbs.
price is 375 plus shipping.
the 96-00 civic cpe will be finished this week and I'll post pics of that when its finished.
two methods of mounting will be available , one retains full function of the sunroof glass and uses the factory rubber seal , it simply bolts in place of the glass which is the heaviest part of the assembly , the other will anchor like mine , with rivets from the inside.
the next application will be 94-00 integra and we also have an 91-94 SE-R unit already finished.
these are HAND made , they do have slight imperfections but the pattern and the weave is perfect , you will need to specify whether you would want shiny or dull , it impacts the weight of the unit slightly , mine is the dull finish.
Bling Blang ------
Bling Blang ------
Re: carbon kevlar sunroof done (pics) ...... 56k NoNoNoNoNoNo (Doctor CorteZ)
im not sure what its trying to accomplish. looks i say nay, replacing the glass for cf is so so.
That is awesome, I have been thinking of replacing my moon roof with a plexi one or something of the sort. I didn't even think of that. That looks really sweet.
not to nag, but are they all gonna look so "dirty" on the inner side? Not that i want one...but just curious if thats from the fab process of making it ?
That is sweet, I don't have a sunroof, but that is nice..................what kind of venues/events do you race that car at?
Re: carbon kevlar sunroof done (JDM_SiR_II_EG)
Doctor C: It was hard to see in the photos but are you still using the rubber surround seal from the oem sunroof or is that Black RTV? Waht weight cloth did you use?
Nice work
The inner Armid layer is a good safety measure, it will help keep the composite part from breaking into separate pieces like a full carbon part would.
[Modified by SLPR, 9:59 AM 3/18/2003]
Re: carbon kevlar sunroof done (Soundwave)
I thought what it was "trying to accomplish" was obvious.
you should read up on chassis/handling dynamics and let me know what you think afterwards.
Re: carbon kevlar sunroof done (SLPR)
Nice work
Nice work
not sure on the weight of cloth , my CF guy made it , I only helped out / watched.
Re: carbon kevlar sunroof done (urbanlegend21)
Are you worried about flex when air is traveling through the car or is the Kevlar stiff enough to hold up?
its stronger than the roof of the car.
Re: carbon kevlar sunroof done (Doctor CorteZ)
Nice part... sure beats replacing the roof...
Is the sunroof mechanism still attached if only the glass is replaced?
Re: carbon kevlar sunroof done (SpoonEK2)
no leaks either , the fit is so tight it goes in with a rubber mallet.
Re: carbon kevlar sunroof done (t0p_sh0tta)
So will this be the same as the sunroof glass, which will open up? cuz it loks like you screwed it into the metal where the glass was meaning that it would never open up.
Re: carbon kevlar sunroof done (mantic6t9)
Interesting. Can you tell the difference with the extra weight removed from the roof?
I can tell the cage is there and the duckbill changed the car dramatically , but the sunroof aside from weight on a scale , I cant tell.
Re: carbon kevlar sunroof done (Echo7847)
I did the duckbill , cage and sunroof at once.
Re: carbon kevlar sunroof done (Jun)
Maybe you could start making the fuel door as well.
I dont do cosmetic stuff.
