car randomly turns off and wont start
i am throwing a cel its 15 for the ignition output signal. i havent been able to drive my car in days because everytime i am able to turn it on it runs for about 5-8 mins and then turns off on its own and then it just cranks over and doesnt start but after i leave it for 2 hours it will start again and do the same thing. any idea whats wrong?
Re: car randomly turns off and wont start
you car could have possibly jumped time. Have you check to see if everything Is at top dead center??? Have you replaced your timing belt recently???
what does that mean? lol. well i have recently had a friend fix my timing and he said it was a tooth off retarded.
this is for a code 15, ignition output signal, from the helms manual.
disconnect 2p connector from dizzy, with igntion switch turned to on
measure voltage between the black/yellow(+) and body ground.
is there battery voltage? yes? continue...no? fix open in blk/yel and ingition switch
continued.
reconnect 2p connector, turn ignition switch to on.
test voltage between A21 (+) and A22 (+) with A26(-) on the ECU
is there 10v? yes? substitute known good ecu and retest....no? replace ignitor unit or repair short between yel/grn wire and ecu A21 or A22.
note: if there is a short the ignitor may be damaged
now my best guess, since the ignitor unit is notorious for going bad in these things, i would go ahead and source one out and replace it
continued.
Mark D. Surface
01-31-2005 12:15 PM
ActiveAero
09-27-2004 10:33 AM
Honda Virgin
06-02-2004 12:34 PM
