CAR NOT STARTING NORMAL?
WHEN I START MY 92 CIVIC CX UP IT ACT LIKES IT NEEDS MORE FUEL TO STAY RUNNING BECAUSE IT WILL START CUT OFF,START CUT OFF,THEN I GIVE IT A LIL GAS IT STALLS AND RUNS WHEN IT GET ENOUGH FUEL ITS SEEMS,SO I CHECKED THE FUEL FILLTER ITS GOOD.
WHAT ELES COULD I CHECK ???????????? SO WHAT DOES IT SOUND LIKE TO YOUALL
I NEED THE HELP PLEASE IDEAS OPEN
Re: CAR NOT STARTING NORMAL? (don24)
1.] re-read the title of your post.
2.] turn off your effing caps
3.] I had this happen to me, but it turned out to be my chipped ECU frying. I spent over $350 on parts before I figured out the problem though, so good luck.
if it starts it is not a starting problem it is an idle problem. it could be alot things timming, tune up spark plugs and wires cap, rotor i was going to say fuel filter do a basic tune up if it has not had one in a few years then go from there. that is just my advice trouble shooting the car would be better for any one to tell you specificly what is wrong. a vacume hose may have cam off or rotted ? many things
