CAR NOT CRANKING NEED HELP PLEASE !!!
hey guys .. basically .. cars not starting ... car is a 96 honda civic cx ..stock motor ... i drove the car the whole day started just fine until later this night around 11 ... i turn the key and my cluster lights turn on ..headlights go on everything power works except the motor wont crank battery seems fine .. i let it roll down the driveway and started it in reverse .. i drove it around clutch is fine .. but when i turn it back off it doesnt crank again .. extremely lost here and im supposed to be taking a road trip tomorrow ...
my cuzin was installing my alarm yesterday but something wasnt working out right so he left all the wires and jus removed the brain ... car still started up fine with that said and all wires were covered no visible wires so shouldnt be anything making contact... also all of my fuses are perfectly fine .. i checked starter fuse ignition fuse and something else running out of ideas ?? anyone ??
Re: CAR NOT CRANKING NEED HELP PLEASE !!!
is that little rubber piece usually in a blueish colour ?? cuz i thing theres a hole on the top of my clutch where that rubber would go and i did notice some extra rubber on my carpet yesterday while my cuzing was working on the car... any idea what i can use in its place ?? or where i can purchased this oem? thanks
damn your good lol .. i used my finger and pushed the safety starter in while turning the key and cranked right up .. thanks alot really big help .. and as for replacement .. any suggestions??
i had an extra gas pedal laying around with a rubber piece that looks similar .. i might try to fit that thanks again man great help
you could also unplug the switch and shove a paper clip in there(in plug not the switch itself). bright side of that is you wouldnt need to push the clutch in anymore to start the car
Not a good idea because it would remove the "safety" feature from the starter switch.
Is that the same for a 92 honda civic..because yesterday i was able to drive to work..with no problems..then i went to pick up my son on my lunch break from school it ran fine i had no sign of problem..i parked my car and turned off the car..i come back to my car to start it but it wouldn't start..I tried the jumper wires hoping it was a battery..headlights go, but the motor wont crank battery seems fine..
mattchew_2124
12
02-13-2014 11:34 AM
superhatchbackbros
50
06-01-2009 11:17 PM
Eg6_rAcEr
14
11-08-2007 12:34 PM
