has anyone replaced or painted coupe rear side window seal?
Old 11-26-2012, 03:13 PM
Dead CIVIC's Avatar
Default has anyone replaced or painted coupe rear side window seal?
my rear side window seal is so faded, or dry rotted it looks really bad.
I'm thinking about painting it, if so what color should I do... flat clack? semi gloss? or is it easily replaceable?
I'd much rather replace it but I cant find the part on any site, or i just don't know what its called... any input is appreciated thanks.
Old 11-26-2012, 03:17 PM
Dead CIVIC's Avatar
Default Re: has anyone replaced or painted coupe rear side window seal?
http://www.hondapartsunlimited.com/p...quarter-window
found it 7&8, how is that part replace
Old 11-26-2012, 03:19 PM
beyond305's Avatar
i was at advanced auto and saw some paint for vinyl/rubber trim. VHT has a vinyl spray paint thats pretty good too. you would just have to make sure to mask the area off really good. Id go with a satin finish.
http://www.autopartswarehouse.com/sk...apwSP950sppavh
Old 11-26-2012, 07:16 PM
Retired Moderator
EsotericImage's Avatar
dont paint it.. your putting a bandaid on a problem..
if its dry rotted then just replace it. The link above has the part
Old 11-27-2012, 07:46 AM
RSXting's Avatar
You can get the seals from BKHonda under rear quarter glass. I think it was like 40-50$. BK has good prices with 30% off Honda and they're quick. Check out my build thread. What I did was I painted that area completely (with the rear quarter glass and seal out) and I put the new seal on (OEM from Honda), see what touches, wire wheel the paint off that the seal would touch off, and use polyurethane to seal it to the window. Pretty easy but make sure that you purchase the Honda OEM seal. Hope this helps
Old 11-27-2012, 07:49 PM
Dead CIVIC's Avatar
sounds easyish, I'm gonna check out your thread, I changed my mind about painting it, I'm going to replace it, what does BK stand for?
Old 11-28-2012, 03:22 PM
H-T White Ops
NOFX's Avatar
If you do not desire to replace the seals, I would suggest dying the seals black instead of painting them. The dye lasts a long time and can not flake.
srok1
10-12-2009 12:38 PM
lexan2.2sedan
07-13-2008 10:48 AM
Immortal-Prelude
01-05-2008 02:04 PM
Quick Reply: has anyone replaced or painted coupe rear side window seal?
