Car goes to the left.....
When I bought my car ( 94 Civic EX with 133k) about 6 months ago the car came with some low profile tires on the front and normal tires on the rear. The car would always lean to the left and it bugged the **** out of me. So I replaced all the tires and had an alignment done, I was hoping this would cure the problem but It doesnt seem to have done the job. What could cause this? The suspension and steering stuff looks pretty old and am thinking about replacing things like shocks, springs, axles, lca, etc. .....
Re: Car goes to the left..... (2manycars2choose)
The car leans to the left is what you are saying correct? All of the Civics I've ever seen do this. It's just the Honda Civic Gangsta Lean y0! The only way you're going to get rid of it is coilovers.
Re: Car goes to the left..... (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">The car leans to the left is what you are saying correct? All of the Civics I've ever seen do this. It's just the Honda Civic Gangsta Lean y0! The only way you're going to get rid of it is coilovers. </TD></TR></TABLE> yeah coil overs will fix it.. mine does th same thing..
i think he's talking about his car pulling to the left. on my car it pulls to the left kinda hard, the problem was a bad cv joint.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote"> All of the Civics I've ever seen do this. </TD></TR></TABLE>
wow, mine goes tothe right like ****, when I`m on the high way and I wanna changed lanes to the right, I just let go of the wheel for 3 seconds and i`m in the other.
but this all started when I hit a curb this winter, I`ll get it fix in the spring
Re: Car goes to the left..... (Daniel_san)
bad cv, mine did it , new cv joints fixed it right up, if it clicks in turns also then its definatly the CV, if not maybe balance the wheels too??
Re: Car goes to the left..... (blackcivic95)
Yea, Like when you are on a straight road and you let the wheel go, it likes to pull to the left. I had the tires balanced and the car aligned. Ill go ahead and replace the cv joint and all and see if that will fix it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2manycars2choose »</TD></TR><TR><TD CLASS="quote">Yea, Like when you are on a straight road and you let the wheel go, it likes to pull to the left. I had the tires balanced and the car aligned. Ill go ahead and replace the cv joint and all and see if that will fix it. </TD></TR></TABLE>ok well thats a different story.. you sad your car leaned .. you didnt say it pulled.. if you already had the car aligned then yes it is most likely your cv joint...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel_san »</TD></TR><TR><TD CLASS="quote">
but this all started when I hit a curb this winter, I`ll get it fix in the spring</TD></TR></TABLE>
ROFL... I dunno that's hella funny to me because I've done that in my cx... I just chalked it up to the fact that I drive a $2000 car and it will never ride like a bmw or other high end sporty vehicle.
quinnrob
Honda Civic (2006 - 2015)
13
06-13-2007 10:36 AM
95civic LS
03-30-2005 03:24 PM
