car "knocks" or "taps" when cold - goes away after warmed up.
sounds like a light tapping when I start it cold, the tapping accelerates as I hit the gas.
goes away really quickly (1 to 2 minutes).
car was oil starved before I took ownership (valve stems/seals leak) and now I have to decide whether it is going to be cost efficient to change the timing belt/water pump and replace the valve stems/seals AND whatever this tapping/knocking is - OR - drive it till it dies and replace the engine at that point.
my Q is how could I determine what is making this noise, or is it hard to tell without hearing it? compression tests were all ok (150, 150, 145, 150) and it runs great, just curious more than anything what could cause it.
oh jesus.. that would be real great since I bought this Civic because my 94 Bonneville had a clearance problem!!!
any way to confirm/rule out if this is the case?
in my Bonneville it doesn't knock until it warms up, other way around here, knocks until it warms up and only when its cold outside it seems.
HLvet
12-08-2014 05:02 PM
SVOHK
09-07-2014 08:19 PM
Probot
60
03-26-2007 10:36 AM
