Can't find IACV plug on my harness HELP.. ?
Hey guys so like the title states i really reaLLy cant find where in the world my iacv plug is ? i have all me connections plugged and there are about 2 big connectors under the intake mani which are dead stops and there are another 2 left one which is a 3 plug which i was told is suuposed to go to my crank fluctuation sensor , which i dont need to hook up anyway because the p28 ecu with jumper harness im using doesnt look for it and the other one is a round one which i thought was the iacv when until i flipped it over and looked in the back and saw the it had only 1 wire going to it and the second hole has a plastic round thing covering it.( so its only 1 wire running to it). SO where is my iacv plug damn it. please someone help it would be greatly appreciated.
Car Info: 1997 honda civic ex .Had a single cam d series in there then this past few days i swapped it to a gsr (b18c1) AND am having trouble with harness. Am using a p28 obd1 with jumper harness.
any help would be appreciated .Thank you.
Re: Can't find IACV plug on my harness HELP.. ?
knock sensor is 1 wire. You have any evap stuff like canister? maybe you used that plug on canister? CKF- wht/red, blue/org, brn/blk. IACV- Blk/blu, yel/blk, evap purge valve-red/yel, blk/yel
Pancho2193
11-24-2012 10:02 PM
