Candied taillights??
Does anyone know how to candy there taillights, and if so, do u know if u could candy euro lights? if u have any feedback, hit me up, thanks i appreciate it!...
jay
jay
Re: Candied taillights?? (EG2 SiR)
your saying that the translucent red paint at the hobby shop would cover the taillights and wouldn't the paint fade or fall off the taillight if it was raining ?
Here is a How-To i wrote for another board a couple weeks back,..hope this helps and sorry for the lack of pictures
Materials needed:
1.Testors Candy Apple Red transperant paint (you can find this at your local Hobby shop that specializes in remote control cars,...or if you have a local Micheals craftstore,..they have it also)
2.3M masking tape (i use 3M because they make the best products)
3.Automotive clear paint (you can find this at any auto parts store) this is optional
4.Rubbing alcohol (this will be needed to get the surface that will be painted cleaned,...i suggest you clean off the WHOLE lens,...for reasons i will explain later)
The Process:
This DIY is quite easy as long as you can paint pretty good
1.first off, you will need to clean the lens,..the whole lens with the rubbing alchohol,...make sure to clean it good so that the paint will stick well
2.you will need to mask off ANY area you would not want painted,..this includes the bottom part of the taillights that will remain clear and also the back of the taillights because there will be overspray
3. now for the painting,...make sure you do the painting in an area that is pretty much clean,...you dont want flying dust to fly into the paint and stick
you will now apply a thin coat of the Testors paint to your tails,...you will want Thin coats because if you put on thick coats,.you run a chance of the paint running which is bad and will ruin the job,...make sure to apply the paint evenly to all areas that is being painted,...i used 3 coats total of the Testors paint,...waiting 15 mins in between each coat before putting on the next coat,...once you are done apply all the coats of the testors paint that you desired,...i suggest you wait atleast an hour before going to the next step
okay so now you are ready to remove the the masking tape that is on the bottom part of the lens that remained clear,...becareful not to touch the red painted area because it will not be dry enough to touch yet,...so carefully remove the masking tape from the bottom part of the lens,...*note* you should have not taking the masking tape off the back of the taillights,..just the tape that was on the actual lens was suppose to be removed
now i took some rubbing alcohol and i again cleaned the part of the lens that was not painted,....the reason i suggested cleaning the whole lens was because i sprayed clear onto the whole taillight instead of just the part that was red
Now spraying clear should be the same process as spraying the Testors paint,...again thin coats,...and apply evenly,...i again used three coats of the clear,....waiting 15 mins in between each coat,...once you have applied the desired amount of coats of clear,...you place the taillights in an area that nothing can get to them,..so nothing flying and what not can stick to the paint,...i suggest leaving the taillights sit overnight to ensure complete drying of the paint,...come back the next day and remove the rest of the masking tape left on the back of the taillights,..install the taillights and enjoy
okay a couple things to note:
1. First to clear up any confusion....this question has been asked numerous times....YES you do paint the OUTSIDE of the lens,..you do not need to take the lens off the taillights to do this
2. i said to mask up the bottom of the lens for the taillights in my DIY,...but you can mask the top and paint the bottom if you would like,...its your preference
3. when people are talking about "smoking" or "tinting" their taillights,..they are pretty much gonna be using the process i used to paint the taillights,..but you will need RC car tint paint for the smoking or tinting of your taillights ( i have only seen this at hobby shops that specialize in RC cars)
4. for all you 5th gen civics and del sol owners out there that desire amber corners but do not want to pay to much for them,...you can use the same process i used to paint my tails, to paint your corners,...the paint you will need is orange Krylon stained glass paint (i did the krylon paint to my sidemarkers and it looks hot) the krylon paint can be purchased at your local craftstore,..hopefully Micheals craftstore
5.Its optional to use clear on your tailights,...i only did because i felt it will help the life of the paint to last on the taillights,...i recommend using the clear
Materials needed:
The Process:
Re: Candied taillights?? (IIIIIIIlllIIllI)
Mine were all clear before I fixed them.
I did not use clear. Last time I used the clear and it turned yellow over time and also flaked.
Nice man, I wanna '98-01 covert' my 94-97 lenses. I wonder how it would look having that paint over red and orange
Re: (WiDeBoDyEK)
thanks for all ur help man, i candied them and they look great, all i need to do is learn how to post pictures on here, can any help..lol?
Jay
Jay
400 HP Club
Re: (IIIIIIIlllIIllI)
http://www.we-todd-did-racing.com you can host your pic and then post the IP between the IMG tags.
mordezmoncou
14
05-30-2005 03:49 PM
