Canadian Wiring Harness - 3 wire to 4 wire Alternator Plug
Is it possible to convert the 3 wire alternator plug on a Canadian harness to a 4 wire alternator US plug?
I have both harnesses (US - and Canadian)....
Can I match the colors and run a wire back to the ECU pin of the AltC (Alternator control pin) for the extra wire? From my research it will throw a code if I leave this 4th pin disconnected, because the alternator will constantly be charging.
Here's a picture of the plug itself:
Thanks! Help is appreciated greatly!
Wire colours please ... and OP, you're in good hands here ... I see some of the most helpful Canadians on this board responding in this thread.
PS., I do know that the 5th Gen Civics USDM vs. CDM used different alternator plugs.... however, this is a mystery.
Wire color is white/green pin = A19. The harness is also missing D16 (ELD).
I guess the main question now is....
Does my ECU (JDM P72 B18C - P72-013) look for the ELD... otherwise I will run without it.
Lots of people with chipped OBD1 ecu's clip this wire.
I soldered on the 4 plug connector to my 3 wires on the EK harness.
The 4th wire is for Ï forget right now EDL ?!? "but you dont need it. I terminated the 4th wire in the loom.'and works great.
""Can I match the colors and run a wire back to the ECU pin of the AltC (Alternator control pin) for the extra wire? From my research it will throw a code if I leave this 4th pin disconnected, because the alternator will constantly be charging. ""
False, I did this with an OBD1 b18b swap in the EK , never threw a code and used the stock p75 ecu
So just attach the 4 pin to the 3 pin harness and tie off the spare wire?
My JDM ECU SHOULDNT look for ELD... anyone wanna comfirm that?
It's a JDM P72-013... B18C OBD2A GSR etc etc
As far as the 4 wire, 3 wire OBD2 plugs, as has been mentioned, or at least hinted at, Canadian OBD2 Civics don't have an ELD. As a further aside JDM Civics use a 4 wire alternator, so i'm guessing they have an ELD, so the ECU may look for one.
I found this:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/obd2b-3-wire-alternator-obd1-4-wire-help-searched-1766948/
I'm gonna call some tuners tomorrow and see if they if my ECU looks for one.
PS: The altC wire runs to the ECU at A19... then the "ELD" wire runs from D16 to the cabin connector I think. But I have neither pins on the Canadian harness.
The ELD is not something I wanna wire in...
So I manual swaped my crv an manual loom has thr 3 plug an think altornator on way out so I can just put 4 wire plug on with out white an green wire ?
user 20002452454
Dec 8, 2021 03:58 AM
lovehondas
Jul 19, 2012 04:47 PM
Citystars
Nov 30, 2007 03:31 PM
