can you put a 00 si transmission on a d16y8
i searched but it wouldnt let me include si or ex so after about 30 min of searching i said screw it. So anyways..... Can you put a 99-00 si transmission on a d16y8?
Re: can you put a 00 si transmission on a d16y8 (Luserkid)
no you cant the y8 is a d series motor, where the 99-00 si is a B series motor. if your tranny went out on you on your y8 then any tranny from 92-00 off any d series will work.
Re: can you put a 00 si transmission on a d16y8 (sohcvtec1995)
Also, your motor comes with the best tranmission avaliable for the DSeries motors so if you need a replacement tranny, buy the same one you have now.
Re: can you put a 00 si transmission on a d16y8 (EVIL Hx Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL Hx Coupe »</TD></TR><TR><TD CLASS="quote">Also, your motor comes with the best tranmission avaliable for the DSeries motors so if you need a replacement tranny, buy the same one you have now.</TD></TR></TABLE>
The gearing might be the best dseries tranny but it definitely isn't the strongest.... The steel shifter forks are superthin and don't do well with any hard shifting... The 92-95 si trannies are a lot stronger. The forks are made out of aluminum with some pretty heavy duty webbing so they don't flex... They should have added the webbing to the steel shift forks on the y8's trannies then they would be the best....
I wish a 99-00si tranny would fit on a dseries motor.....
Destroyer of Dseries trannies....... 2-y7trannies and 3-y8 trannies Currently running a z6 tranny for the last 40,000 miles with no problems.... y7-t 195whp
Electrician
No. The D16Z6 and D16Y8 transmissions are the shortest from all the D-Series.
Only way to get even shorter gears is custom building your transmission with hybrid gears and different final drive.
Re: can you put a 00 si transmission on a d16y8 (4door_ridin)
I got a chance at a 95 si tranny with 32k miles but the guy wants 200 for it and another 75 for shipping. Good deal?
Hey 4door_ridin theres 2 si trannys on ebay right now not too bad prices right now i was going to bid but i cant use them. Check it out man
Re: can you put a 00 si transmission on a d16y8 (hondadude96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude96 »</TD></TR><TR><TD CLASS="quote">Say what? Listen if you are going to be a help then thanks, but if not im sure you got something better to do punk. </TD></TR></TABLE>
oh no not hardcore keyboard rhetoric
If you've got nothing better to do why don't you get aquainted with the "search" key and the "sticky" posts
- next
- next
Re: can you put a 00 si transmission on a d16y8 (dohcVTECeg2)
Hey stormy why dont you check your chair i think you got a stick pointed strait up in it. Pull it out and you should be ok. I swear man just cause you been here for 2 years doesnt mean you rule this thing so go shut up and listen to your micheal jackson records and quit wasting my time.
Thanks to everyone else
Well i cant find anything cheap so it looks like i might have to go with the si tranny. So what im wondering is are the ratios about the same? Am i going to lose any performance? I heard they were different but dont really know much. Any help will be appreciated.
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude96 »</TD></TR><TR><TD CLASS="quote">Hey stormy why dont you check your chair i think you got a stick pointed strait up in it. Pull it out and you should be ok. I swear man just cause you been here for 2 years doesnt mean you rule this thing so go shut up and listen to your micheal jackson records and quit wasting my time.
Thanks to everyone else</TD></TR></TABLE> Stormy thought a FITV was a IACV and he said a D15B has no IACV??? Anyone agree with this statement...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude96 »</TD></TR><TR><TD CLASS="quote">can you put a 00 si transmission on a d16y8</TD></TR></TABLE> HAHAHAHAHAHAHAHA you should try it
oh shut the **** up you little bitch. you wanna fight???
Re: can you put a 00 si transmission on a d16y8 (stormy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stormy »</TD></TR><TR><TD CLASS="quote">05 members own</TD></TR></TABLE>
they're so smart!!
they're so smart!!
Re: (specv5150)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 »</TD></TR><TR><TD CLASS="quote">no one makes a D-B adapter plate like the H-B adapters? </TD></TR></TABLE>
hey thanks for selling me that crank pulley holder. that thing is great
Re: can you put a 00 si transmission on a d16y8 (The Internet Tough Guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Internet Tough Guy »</TD></TR><TR><TD CLASS="quote">they're so smart!!</TD></TR></TABLE>
Re: can you put a 00 si transmission on a d16y8 (fishnfst)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishnfst »</TD></TR><TR><TD CLASS="quote">The gearing might be the best dseries tranny but it definitely isn't the strongest.... The steel shifter forks are superthin and don't do well with any hard shifting... The 92-95 si trannies are a lot stronger. The forks are made out of aluminum with some pretty heavy duty webbing so they don't flex... They should have added the webbing to the steel shift forks on the y8's trannies then they would be the best....</TD></TR></TABLE>
can anyone confirm this statement? I have been hearing the total opposite that the y8's are stronger ever since i signed up here...
Imperious: Mod of Valor
What he said.
What he said.
