Can you fix a dented header?
Old 01-14-2003, 06:14 PM
dragnize's Avatar
Default Can you fix a dented header?
oK, So i got a 4-1 header for my car recently (used)
It had some wrapping around the right pipe which i removed cuz i was wondering what it was for.
the guy said it was to protect the hoses close to it.
So after awhile all is ok, until today I checked under the hood and saw that the right pipe had dented (o yeah, also, it looked like it was welded, wasn't smooth)
And it was like, a huge dent. Z told me to come on here and ask if anyone knew about if it could be fixed? drilling a hole in it or something?
help meeeeeeeeeee!!!
ps. i emailed the guy i got it from and im waiting for a response on what happened to it.
here's the pic EDIT: thanks EKology (see pic below)
[Modified by dragnize, 10:17 PM 1/14/2003]
Old 01-14-2003, 06:18 PM
95IntegraGSRAZ's Avatar
Default Re: Can you fix a dented header? (dragnize)
Thats link takes me to an album called "Pets". Wrong fourm
Old 01-14-2003, 06:41 PM
Dr. EKology's Avatar
Here you go:
Old 01-14-2003, 06:46 PM
CLERIC's Avatar
Default Re: Can you fix a dented header? (EKology)
Correct me if I am wrong but ive always heard the wrapping was for heat reduction??
[Modified by bustersandman, 9:46 PM 1/14/2003]
Old 01-14-2003, 07:12 PM
Solbros Owns Me
Evs-One's Avatar
Default Re: Can you fix a dented header? (bustersandman)
Yeah, in this case to keep the heat down so the fluids don't get too hot.
I don't know what you could do. Possibly pull it off, and possibly pry it back to shape from the inside, since it isn;'t too far from the port.
Old 01-14-2003, 07:43 PM
euclid's Avatar
Default Re: Can you fix a dented header? (Emerica)
I don't know what you could do. Possibly pull it off, and possibly pry it back to shape from the inside, since it isn;'t too far from the port.[/QUOTE]
i dont know wtf the previous owner did to it to dent it like that in that spot.
[Modified by euclid, 12:45 AM 1/15/2003]
Old 01-14-2003, 07:46 PM
White Lightnin's Avatar
Default Re: Can you fix a dented header? (euclid)
Take it off and beat the guy who sold it to you with it. That sucks.
Old 01-14-2003, 07:49 PM
intezn's Avatar
Default Re: Can you fix a dented header? (White Lightnin)
Mazda ?
Old 01-14-2003, 07:54 PM
nwdave's Avatar
Default Re: Can you fix a dented header? (intezn)
Mazda ?
Miatas rock
I second White Lightnin's suggestion.
Old 01-14-2003, 08:50 PM
projectM's Avatar
I dont think that you can fix that. I say you go back and return that crap header and buy yourself a brandnew one.
Old 01-14-2003, 09:21 PM
p0pk0rn's Avatar
You can try this - Plug all the ports with some sort of stopper, maybe something rubber. Now make a hole in one of the stoppers so you can wedge an air hose into, thus pressurizing the header. Now get a blow torch and heat the dent, if there is enough heat and pressure, the dent will pop out. A buddy of mine used this method for his dirt bike pipe which was dented on a botched landing.
A bit tricky but it just might work.
Old 01-14-2003, 09:24 PM
ProEater's Avatar
Default Re: Can you fix a dented header? (p0pk0rn)
if you do this and it works, ill give u 5 bux, not doubting popkorn. just wanna see if it will work
Old 01-14-2003, 09:56 PM
poo flinger
Guest
Posts: n/a
Default Re: Can you fix a dented header? (ProEater)
Easiest way is to drill a hole in the middle of the dent. Heat the dent up, put some sort of hook in the hole and pull the dent out. Then seal the hole. You will need someone that can weld.
Old 01-14-2003, 10:41 PM
SupaSh0ck
Guest
Posts: n/a
Here you go:
8-D SpD
Old 01-15-2003, 06:48 AM
dragnize's Avatar
Default Re: Can you fix a dented header? (SupaSh0ck)
8-D SpD
what?
.. thanks for ideas, i'll try them out soon hopefully. if that doesnt work, there goes 500 for new one
Old 01-15-2003, 12:58 PM
nwdave's Avatar
Just replace that header with this:
(wasn't sure of the year of your car)
Old 01-15-2003, 01:02 PM
Hang On's Avatar
Default Re: Can you fix a dented header? (delsolguy)
I know it can be done and for cheep , my friend had a Spoon header fixed that looked like that!
mmmm Spoon
Old 01-15-2003, 05:50 PM
dragnize's Avatar
Default Re: Can you fix a dented header? (Hang On)
mmmm Spoon
how did he do it? did he drill a hole?
Old 01-15-2003, 05:51 PM
dragnize's Avatar
and for that turbo pic.... yeah right i WISH. saving $$
btw.. mine's a 99
Old 01-15-2003, 05:55 PM
-Whitey-'s Avatar
pull the header off and get a piece of pipe and try to pry/pop it back out the best you can it will always be there but the better you canmake it look the better it will flow on the inside
Old 01-15-2003, 06:05 PM
SuperTwinz's Avatar
https://honda-tech.com/zerothread?id=327430
https://honda-tech.com/zerothread?id=345487
Old 01-15-2003, 06:14 PM
blufke's Avatar
ive heard about that method too. a dirtbike rider told me about that.
Old 01-16-2003, 10:52 PM
SpoonEK2's Avatar
Default Re: Can you fix a dented header? (blufke)
take it to a muffler shop and they'll probably heat it up and poke it out from the inside...they might do the air pressure thing, but it all depends on the thickness of the steel. Replacing the header on my friends M1 was a PITA x5.
Old 01-17-2003, 12:32 AM
INVALID's Avatar
Location: Why so you can pretend like youre interested, FL/OK
I will have to talk with my friend last I remember he got a header with a dent in it, granted I did not view the picture, but can imagine what it looked like. Anyway, he was telling me about something that would actually be pulled through the header like a round cylinder or ball. I will have to ask him what he did to solve this problem or show him the thread.
Old 01-17-2003, 04:01 PM
dragnize's Avatar
Default Re: Can you fix a dented header? (SHAUNTS99)
the header is made from 304-stainless steel
this is just pissing me off. all throughout the process of ebay , the seller responded to my emails so quick (and I asked ALOT of questions). now i have to email him the same questions TWICE before i get an answer. and i'll AIM him to tell him to ck his emails, send him a msg on the miataforum to ck his emails. UGH
oh yeah, he is a member on the miataforum and im fixing to post a post about it on there.
and im trying to file a claim thru ebay but i dont seem to know how to but im learning
uberEFtuner
02-12-2011 06:56 AM
RotaryPWR
11
08-20-2010 12:23 PM
b17rider
11-01-2008 08:37 AM
GSR_integra
11-26-2007 06:58 PM
Maireeka
05-28-2006 08:09 AM
Quick Reply: Can you fix a dented header?
