Can a stock ITR airbox fit into a 6th gen hatch w/B16A?
Re: Can a stock ITR airbox fit into a 6th gen hatch w/B16A? (skafia)
My friend has a B18C1 in his '97 CX hb and he has an ITR air box. It fits fine it just doesnt bolt in. He had to rig the mounts to secure it. I dont see why it wouldnt fit with a B16.
Clearance wise, it should be OK; I say that because I am using an EK version of the ARC induction box in my '00 Si and it is larger than the ITR airbox.
[Modified by kengs, 12:30 AM 8/18/2002]
Re: Can a stock ITR airbox fit into a 6th gen hatch w/B16A? (Doctor CorteZ)
anyone runing an integra (any trim level) air box in a 5th gen civic?
Yep
Yep
regualar intergra box or type r, what sort of mounting bracketts? did the inlet tube and the hole in the fender match? did you retain the stock civic arm? any photographs?
thanks
Re: Can a stock ITR airbox fit into a 6th gen hatch w/B16A? (jcnfh)
I'll take pics
I used a 94-up 3" short ram for a teg
94 LS box
K/N RU-2820 filter
custom bracket
heat wrap
I'll post a full write up when I get time
I can tell you this it is very nice and low key
94 LS box
K/N RU-2820 filter
custom bracket
heat wrap
All DC2 air boxes are the same. The only difference is the tube. GSR bends lower, because of the t.b location. LS and ITR have approximately the same t.b. location. The main differences are tube id taper off more rapidly for LS tube. I think 2.5" and 3" respectively. Also there is a resonator before the outlet of the arm for the LS.
Either LS or ITR intake arms can be used for 6th gen civics. The only other problem is the temp sensor, DC2 do not have one on the intake arm. You can punch out a hole into the arm or use the valve cover return hole and send the valve cover return elsewhere. i.e. oill catch can
The inlet tube to the air box routes off the inside and wraps under to the front corner of the bumper, where the aem cai is located. It does not go through the aem cai hole/stock Civic airbox pickup.
If you don't have a LS or ITR intake arm, all 3" short intake for 6th gen Civics will work.
AEM CAI will not work because, it's only 2.5" and the outlet on the DC2 air filter is 3". Most short rams are 3". A cheap shortie will work. I have a Matrix intake arm which also works. $70 with generic filter.
Re: Can a stock ITR airbox fit into a 6th gen hatch w/B16A? (kengs)
