Can someone help me ID this TB
New User
I bought this TB on EBay it was described as being from a B16a2 from a 99-00 SI but there is no place where to put the MAP sensor. The TPS from a Y8 TB that I have laying around fit but there is no place where to put the MAP sensor. Everything else is there and it has a 62mm bore. Can anyone tell me where it came from and if I can still use it? Also where would I mount the MAP sensor and what would I connect it to? Thanks in advance.
That's the gasket that was sent with it. the PT# is 161176-p2t-004.
Re: Can someone help me ID this TB (Pho Real)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pho Real »</TD></TR><TR><TD CLASS="quote">Pics dont work, try searching the part number.</TD></TR></TABLE>
i got a TB that needs some researching too...any idea where to do this at?
Re: Can someone help me ID this TB (DV98CVC)
http://www.hondaautomitveparts.com has a parts search function, not sure if it works because this other guy's number isn't working.
Re: Can someone help me ID this TB (pucho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pucho »</TD></TR><TR><TD CLASS="quote">Thanks for helping me out, I just went back and fixed the images.</TD></TR></TABLE>
still not working
still not working
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pho Real »</TD></TR><TR><TD CLASS="quote">http://www.hondaautomitveparts.com has a parts search function, not sure if it works because this other guy's number isn't working.</TD></TR></TABLE>
you mean http://www.hondaautomotiveparts.com
i have whats supposed to be a gsr TB, is there a site for acura parts?
Yeah my buddies B16a2 is like that as well, its the JDM version. Just ziptie it to the brake lines that run along the firewall and about 4 to 6inches of vacuum line. or if you want your Map sensor on the TB and dont mind spending a couple hundred dollars USDM B16A2's should have the Map Sensor on it or JDM CTR B16B's will as well.
New User
Re: Can someone help me ID this TB (HondaGSR)
Great thank for the info. Can you tell me what your friend did with the other port? I can see where to connect the MAP (the little port) I'm talking about the bug port (pipe)
That TB looks like a JDM DA6 automatic TB look at the large bracket attached to it its for the Kick down cable used with Auto trannys...
Re: (pucho)
i believe only the obd1 motor had tb's like that with the pipe on top.
my friend obd1 tb has that pie with a place for the map sensor also, but it's a gsr tb.
it looks like a d series obd1 tb. to me..... could be wrong.
Re: Can someone help me ID this TB (eg cookiemonster)
Look at the BIg bracket and the spot for 2 throttle cables to hook up one sopt is for the throttle and the other is for the Auto trans Kickdown cable It could be OBD0 or OBD1 some of the jdm DA6'S came OBD1 with the map still mounted on the firewall.. Hope this clears it up.....
Re: (pucho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pucho »</TD></TR><TR><TD CLASS="quote">$51. Plus $7 shipping</TD></TR></TABLE> WOW!! looks like Ill be putting mine on E-BAy I have like 6 of those things!!....
