Can not remove key from ignition
My sister has a 93 del Sol and is having problems removing the key after the car is shut off. I had new keys made for her at the honda dealers using her VIN and its still the same. I know that the engine was re-built by the previous owner who didnt believe in warming up the car no matter how cold it is outside. I notice that the auto shifter light is out. Is there a sensor that doesnt let the key come out if the car doesnt think its in park?
Thanks for all your help
NEW INFO
I just found out from her that the key does not go all the way to the off position. It is just slightly off if that helps.
Thanks again
[Modified by sol-man, 5:29 PM 1/16/2002]
NEW INFO
Thanks again
Re: Can not remove key from ignition (DX_Hatch)
Jiggle shake rattle and roll; no luck.
Shift into park drive neutral still no luck.
Start and shut off the car still no luck.
Re: Can not remove key from ignition (sol-man)
if the steering wheel isnt center d..it ll stick..unless its got a lever that release s the key..sorta like the steering wheel lock
now is the time to get the Push Start button....maybe new ignition....my friend has a del sol maybe i can ask him if there's a tricky way of getting the key out
How much was the switch to replace granted yours was for a Focus.
Thanks
Thanks
I agree with B18, remove the center console and adjust the auto shifter. There is a switch in the shifter, and if the shifter isnt all the way in park it will not hit the switch, so the key stays locked in. I think there is a screw at the base of the shift lever, but I cant remeber for sure.I hope this helps! Later!
[Modified by iceburgslim, 3:16 AM 1/17/2002]
always a last resort is are the crooks at the dealerships that ll say they need to replace have ur car to get the key to come out
Any other ideas?
I only thing I found after removing the center console was a sliding switch that controls the dash light to show what gear your in.
it also controls the solenoid that keeps your key in the ignition. When the key doesn't come out- you will probably notice the Park light is not on in the guage cluster. It probably either needs adjusted and/or cleaned or replaced.
you may be Del Outta Luck- it is possible the lock cylinder has been messed up by either wear or a worn key. Does the key turn back to the lock (0) position? If so- you will need a new ignition lock assy. If it does not turn back to (0) I would try to disconnect the ignition switch harness- you will be looking for a brown plug about an inch wide that is just above the dash fuse box- you will see the harness going into the steering column- unplug this and see if the key will turn back to (0).
Re: Can not remove key from ignition (fixhondas)
Try sprayin some WD40 in it. Fixed my key prob. It lubed up the cylinders inside the ignition and doors.
SavMac14
04-02-2013 09:35 AM
vware1955
09-30-2008 12:36 PM
Hazem
15
12-16-2004 01:54 PM
