Can i use itr endlinks when installing a type r rear sway on a 99 civic?
Hi, i havea suspension question when installing a integra type r rear swaybar, can i use the endlinks from the integra type r... or would i need to purchase 99-00 si endlinks? thanks!
Re: Can i use itr endlinks when installing a type r rear sway on a 99 civic? (Russell Wong)
you will have to modified in order to fit an itr , you are rather of buying a comptech .is just bolton.
Re: Can i use itr endlinks when installing a type r rear sway on a 99 civic? (Spoon1)
I wa stold hte comptech bar is the same as a itr.. with the endlinks and some king moutning brackets i shoul dbe good to go. alot cheaper too. I just need ot know if i would need new endlinks! that would cost more!
I have an ITR rear sway on my EK. Nothing has to be modified, you just have to get the right stuff. You WILL need SI Endlinks, and a beaks reinforcement kit. http://www.beaksproducts.com/
Well, you do have to drill a new whole in your subframe, but that takes 5 mins.
Contact Will at beaks and he can help you get everything you need. I couldnt be more happier with this setup.
Re: Can i use itr endlinks when installing a type r rear sway on a 99 civic? (tonyxcom)
Step by Step how to listed here:
http://www.hybrid.honda-perf.org/tech/ITRon6G.html
Read it and weep......
teaser:
teaser:
Thanks for the help guys.. what do u think of a SKUNK2 swaybar ? any comments?
i have an EK as well and visited Beaks website and checked out the what i needed for the itr sway. i was wondering is it necessary to buy the whole left and right endlink assemblies because i checked out the 52321-S04-003 & 52320-S04-003 at hparts.com and they show 2 different parts for each part number, is it necessary on a EK to buy the 2 different parts for each part #?
Re: Can i use itr endlinks when installing a type r rear sway on a 99 civic? (xhatchracerx)
one is left and one is right. Hparts is good, but also try http://www.hondaautomotiveparts.com under 99-00 SI rear arm or something like that.
Re: Can i use itr endlinks when installing a type r rear sway on a 99 civic? (Trey)
I can't get that link to work...Here is the correct link http://hybrid2.honda-perf.org/tech/6gitrsway/ and http://hybrid2.honda-perf.org/tech/ITRon6G.html
[Modified by 96BlackHB, 12:09 PM 12/13/2002]
[Modified by 96BlackHB, 12:11 PM 12/13/2002]
Re: Can i use itr endlinks when installing a type r rear sway on a 99 civic? (96BlackHB)
here's another good one
http://tech.hybridgarage.com/tech/swaybars.html
cyrk007
07-14-2003 03:26 PM
civicmatt
12-13-2002 04:57 AM
