camshaft
camshaft
i was talking to a couple of people on here about camshafts and they told me that a d15b camshaft is more agressive. they didnt tell me what d15b camshaft it was. does anyone know what d15b camshaft is more agressive, i've serched and can not find any thing
Re: camshaft (94hondacivicvtec)
JDM D15B sohc vtec (92-5) camshaft is slightly more aggressive then USDM d16z6 counterpart but camgear will be required to set the timing as you will be 1/2 tooth off eitherway! unless the cam is free or close to its not worth the pain of the swap!
Re: camshaft (eg6ajk)
News to me. I was of the opinion that the D15b shared the same head as the D16z6 (P28). I supposed its not all that far fetched to have a different cam, but I just cant see it making much, if any, of a difference.
Re: camshaft (Slurp56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slurp56 »</TD></TR><TR><TD CLASS="quote">News to me. I was of the opinion that the D15b shared the same head as the D16z6 (P28). I supposed its not all that far fetched to have a different cam, but I just cant see it making much, if any, of a difference.</TD></TR></TABLE>
head is indeed identical when it comes to casting and so on. but due the fact that the d15b has shorter block and lacked the displacement, different cam was designed to hit that 127hp goal (130ps)!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">all right well i got a d15b2 cam for $10 at upull it. is this the more agressive cam with vtec? </TD></TR></TABLE>
d15b2 cam is not compatible with d16z6..
Cams which work on d16z6 are: d16y8 and JDM d15b (VTi version only) 92-00 SOHC VTEC cams are interchangeable but with some cam timing changes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hondacivicvtec »</TD></TR><TR><TD CLASS="quote">all right well i got a d15b2 cam for $10 at upull it. is this the more agressive cam with vtec?</TD></TR></TABLE>
Haha no. That cam does not have the VTEC lobe and will make less power than your stock cam. We were reffering to the JDM D15b SOHC VTEC motor which makes comparable power to a D16z6.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hondacivicvtec »</TD></TR><TR><TD CLASS="quote">ya but what motor is that?</TD></TR></TABLE>
It's a D15b. They didnt always have a numerical suffix in Japan.
http://www.hmotorsonline.com/s...30021
b.serious
15
11-15-2008 03:32 PM
