which cams
which cams
i am doing a ls/vtec with a 96 ls block and a 92 b16a (jdm) head i have two sets of cams which set shoud i use
1st set is the stock b16a cams
2nd set is a set of 92-93 gsr b17a
which set should i use and why????
1 Post
Re: which cams ((Civic_Duty))
search is your friend:
Your search for cam specs returned 168 results
including:
https://honda-tech.com/zerothread?id=1228639
and even better:
http://asian_e.tripod.com/Honda_Engine_Specs.htm
Chris
including:
and even better:
Chris
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by (Civic_Duty) »</TD></TR><TR><TD CLASS="quote">that was no help</TD></TR></TABLE>
are you illiterate?a little research will reveal that this has been covered numerous times.
the second link i posted is to a page that has EVERY cam spec for every B16 and the B17.
not to mention that a search for "cam specs" will give you the specs on every Honda cam known to man.
Chris
Chris
pootie.teng
02-09-2007 07:39 AM
