Cam caps...?
Cam caps...?
Can i remove just the far left (looking at the engine) cam caps to identify the cams without effecting anything? Or should i remove them all starting from the middle? if i remove them all and have some one hold the cams in place is there a need to set them to TDC? Ultimately i just want to see if in fact i have the cams i am supposed to have or not without taking everthing apart...any help or advice would be appreciated...otherwise if there is some one in SoCal that would over see the project to make sure i am doing it right this weekend let me know and i will throw you a 12 pack or whatever...and one last thing what are the toque specs for the cam cap bolts?
Re: Cam caps...? (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks »</TD></TR><TR><TD CLASS="quote">You can remove just one of them, just torque it back.</TD></TR></TABLE>
and the torue specs? i will look in the bbok but i only have a haynes or what ever one they sell at autozone. thanks
Re: (red02s2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red02s2k »</TD></TR><TR><TD CLASS="quote">cam caps 20 foot pounds </TD></TR></TABLE>
That is only for the 8mm bolts. (12mm head)
It's only 7.2 for the 6mm bolts. (10mm head)
