A/C Vibrating
Re: A/C Vibrating (bustAnut)
check if all the bolts are on holding it to your block. it shouldnt be that bad but from what you explain, it's bad. it could also be a fucked up wheel on the compressor or maybe even the belt. check those first.
Re: (bustAnut)
YOU SHOULD OF SAID SO.
remove the glove compartment and look under at your fan(round thing) and see if that is vibrating. if so then not to sound like a smart mouth, But its your fan. all you have to do is un plug it and remove the fan part(not the whole thing) and go to the dealer and buy a new one, Hope this helps!
Oh if you can live with it for a while then do so. Cuz the fan cost around 40~50 dollars
David Civic
14
06-10-2011 08:34 PM
funtus85
06-25-2010 01:15 PM
CooBreeze
05-19-2010 05:26 PM
