Burnt Smell??
Old 12-03-2001, 08:52 AM
hondachick81's Avatar
Default Burnt Smell??
Lately when I arrive at my destination and get out....I can smell a funny burnt scent. It isn't really bad, and I am not sure if it is related to my cat problem or not! I think it might be my clutch b/c it is hard to shift sometimes, or it shifts really rough! Would it smell burnt?? Anyone have any ideas about what might be wrong??
I am getting my car serviced this weekend so I will know by then, but it kinda worries me.......it's about time for a new clutch anyways!!
Old 12-03-2001, 08:54 AM
DragII's Avatar
Default Re: Burnt Smell?? (CivicGirl114)
what type of smell is it...like electronics, like brakes, like clutch, like rotten eggs (cat problem)
so hard to tell over the net.
Old 12-03-2001, 08:59 AM
Default Re: Burnt Smell?? (DragIIcivic)
well......sometimes it's a stinky gas smell b/c my o2s is not reading properly, and I know what that smell is.
but sometimes it smells burnt.......not gas, or electronics, and I don't know what a burnt clutch smells like!! It could be going bad. 46k with original clutch, and alot of autox and drag racing....so???
It has been shifting hard lately, so that's why I assumed clutch?? just wanted some opinions! thanks!!
Old 12-03-2001, 09:06 AM
DragII's Avatar
try changing your tranny fluid to smoothen up your shifts....that helps alot especially if you have not done so yet.
Old 12-03-2001, 09:16 AM
thanks, but I just had all my fluids changed, but I don't think they did a flush! it sucks too when you get the fluid changed cause with out a flush there's still about half the amount of old fluid left in the tranny
I thought the rough shift could of been the short shifter, but it was shifting really smooth for about 2 months, and now all of a sudden it sucks!! I have never had a manual before, so I don't know alot about the transmission!??
Old 12-03-2001, 09:26 AM
Spade's Avatar
Check the clutch fluid level.......if you are having trouble with the pedal......a burnt clutch smells like the brakes but stronger.
Old 12-03-2001, 09:50 AM
Default Re: Burnt Smell?? (Spade)
well.....i don't know about the pedal, but it shifts rough when I put it into gear!??
like i said though, it needs to be serviced, so whe n I get paid I am taking her in!
Old 12-03-2001, 12:59 PM
New User
HENRY's Avatar
Just a stab at the dark but it could just be a plastic bag or something that got caught on your exhaust piping and is melting. Does it smell like plastic? That happened to me and I couldn't figure out what the heck was wrong until I went to change my motor oil. It could be as simple as that.
Old 12-03-2001, 02:39 PM
B_CRUZ!'s Avatar
Default Re: Burnt Smell?? (HENRY)
Old 12-03-2001, 05:17 PM
DragII's Avatar
Default Re: Burnt Smell?? (eg6_LHD)
did you lube up the ball joint of the shifter w/ high temp grease when you installed it??
Old 12-04-2001, 11:43 AM
yep.....it came with it!!
My clutch is probably fine.....and it is just my exhaust stinking????
Old 12-04-2001, 01:42 PM
SjCiViCHB's Avatar
haha, that happened to mee! twice! godamm its a funky smell, stupid bags, happened with a watter bottel too, stupid things, urrrrr!
and CivicGirl114...so the smell is coming from your exhaust? hmm, mines too but i have a fat hole where the shifter is cause i use to be an automatic....
Old 12-05-2001, 04:09 AM
Default Re: Burnt Smell?? (SjCiViCHB)
well, my exhaust stinks b/c I switched my stock DX exhaust to a performance EX, and the cat isn't reading right...so it smells funny sometimes?!! plan to fix it I hope!????
Old 12-22-2001, 09:57 AM
New User
utensil's Avatar
clutch smeels like a dead rat
Old 12-22-2001, 12:40 PM
Default Re: Burnt Smell?? (utensil)
ewwww.....that's gross!!
It certainly doesn't smell like that! I think I was just paranoid.
speaking of burnt smells....some guy just came into the store and reaked like Dope smoke and mints. LOL.....guess the mints weren't strong enough!
Old 12-22-2001, 02:19 PM
FifthGearOnline's Avatar
that guy needs to cary some febreez around with him
Old 12-22-2001, 04:25 PM
thefordmccord's Avatar
hey, i had the clutch on my ac pump go bad. it smelled freaking nasty. it was like an electroincs/clutch smell combined...
Old 12-22-2001, 09:21 PM
redteg1's Avatar
Default Re: Burnt Smell?? (thefordmccord)
ever try to do a e-brak burnout on dry ground and ur gear engages but the wheels don't spin...i just revved and revved with the gear in clutch out but tires not moving and when i stepped out there was this terrible burnt smell coming from inside and out of my car....im assuming it was the clutch
Old 12-22-2001, 11:27 PM
Halo's Avatar
Default Re: Burnt Smell?? (redteg1)
your problem is clutch realted for sure
Old 12-23-2001, 07:53 PM
D Tranny Guru
Mista Bone's Avatar
never had the problem, SOHC stock motor/tranny I/H/E will light the tires just nicely
17 paces or about 50 feet.
FYI front camber at -1.8 degrees
jonnyrocket56
10-16-2006 01:39 AM
imonx850
08-17-2005 07:27 PM
jhmedcrx
03-02-2005 06:49 PM
eMpAtHy
10-14-2004 11:31 PM
Quick Reply: Burnt Smell??
