building car?
building car?
i have a 94 dx:
B18c1
Drag 3 turbo kit:
t3/t4
Turbonetics wg
Missing link map bypass
Spearco Intercooler
type S blowoff valve
Full custom exhaust by Mufflex into ES oval
ACT Extreme pressure plate Street/strip disc
Fastline Clutchline
CSI catch can
Aem Fuel Rail
Aem Fuel pressure Regulator
Aem Fuel Filter
Earls Performoflex Fuel line
BBK 255lph fuel pump
Msd Sci
Msd Blaster 3 coil
Msd cap
Msd 8.5 wires
Denso Iridiums
Nology Ground straps
Aem Short shifter
NO abs
No Ac
No PS
No cc
Redline Race 30wt
Mobil 1 Filter
water wetter
Electronics:::::
Defi D-Boost
Defi D-EGT
Defi D-fuel pressure
Apexi AVC-R
Apexi RSM
Suspension/Brakes
Gsr Full suspension and brakes
Type R master Cylander/Booster
4040 Prop Valve--------------------------
Koni Yellow Neuspeed ed
Eibach sportlines
Energy Suspension Hyperflex kit
Energy Suspension Motor mount inserts
Goodridge Braided Brake lines
Mcgard Spline Drive starter kit(no rims though thank you woo song jun)
Interior::::
Full Gsr dash/Center Console
gsr steering column
Sparco Torinos
Sparco 4pt Cam Locks
Sparco Grip Pedals
FAKE Type R Shift ****
Stripped hatch
acc carpet
and before its all done aem ems/techedge wideband
wanna run 7lbs
any thoughts on what this thing will do
stopping, 1/4, hp/tq, top speed
iv put so much time and money in need to here a few good things before its done about 1 and a half months from now
B18c1
Drag 3 turbo kit:
t3/t4
Turbonetics wg
Spearco Intercooler
Fastline Clutchline
CSI catch can
Aem Fuel Rail
Aem Fuel Filter
Msd Sci
Msd Blaster 3 coil
Msd cap
Msd 8.5 wires
Denso Iridiums
Aem Short shifter
NO abs
No Ac
No PS
No cc
Redline Race 30wt
Mobil 1 Filter
water wetter
Electronics:::::
Defi D-Boost
Defi D-EGT
Apexi AVC-R
Apexi RSM
Suspension/Brakes
Eibach sportlines
Interior::::
gsr steering column
Sparco Torinos
Sparco Grip Pedals
Stripped hatch
acc carpet
wanna run 7lbs
Re: building car? (integra6650)
UMMMMMMM How about your car is going to assimilate all others????? Cuz it sure looks like it.
[Modified by steve_s, 9:55 PM 2/20/2003]
Don't take this the wrong way. I have no clue what half of that stuff is, but I will say 250-300 to the wheels. That is just a guess. I just wanted to see how close I will be to everyone else.
Whoa, is this your plan or is this in the process of being built? And next time, dont list every last thing you did to your car.. and dont leave out some important **** either. What trim is your turbo, what size is ur IC/exh piping? Any work done to the b18c1? What tires/wheels are you running on? Do you have the stock GSR lsd (jdm) or an aftermarket one? Whats ur redline gonna be at? How much does you car weight with you in it? The things you are asking us to judge are so variable that its impossible to tell..
Re: building car? (Nine)
all this is done except the computer
2.5 ex 3 ic
no lsd yet 15 inch rotas with toya t1s
stock redline
300-400lbs removed
stock internals for now
and sorry for the long list i coppied it directly from a list on my comp
2.5 ex 3 ic
stock redline
300-400lbs removed
Who knows, you could be a good driver or you could be a bad driver, the track could have good conditions or bad conditons.... 1320 times are unpredictable
Re: building car? (EGB18hatch)
What gas are you gonna run?? What oil thickness will you have? What kind of shoes are you gonna wear?? Are your lug nuts torqued properly?? How much do you weigh?? What are you gonna eat before you get to the track?? Did you take a dump the night before to make you lighter?? What kind of oil cap are you using?? Have you changed your bushings out??.......???????
94,strait 30wt race, adidas, of course they are, 175, maybe mcdonalds but most likely ill eat on the way home, an hour before not a whole night, i have a oem gsr cap, which bushings you talking about hehe thanks for the help
