Bubbles in Oil
Old 03-14-2005, 05:10 PM
StreetEG's Avatar
Default Bubbles in Oil
Hey,
So i got a fresh aebs cam seal cause i had a weak p30 stocker from my jdm b16, and i just took a trip to the gas station after a week and gave it a looksy. Saw small air bubbles on the dipstick...theres about 1500 miles on the oil, and about 100 on the cam seal...
I hoping its not the head gasket, but when i got the cam seal on my compression was 205 across the board... so im thinkin its gotta be something else...
when i did a search it said pvc system...but im not too sure what that is so any help would be great....Thanks alot
ERic
Old 03-14-2005, 06:03 PM
StreetEG's Avatar
Default Re: Bubbles in Oil (StreetEG)
ttt...this board moves fast
Old 03-14-2005, 06:04 PM
sohcvtec1995's Avatar
pvc valve. its the engines ventalation system.
Old 03-14-2005, 06:05 PM
StreetEG's Avatar
Default Re: Bubbles in Oil (sohcvtec1995)
any more info... what does it do....did it cause the bubbles? should i be worried etc
Old 03-14-2005, 06:08 PM
ABK
ABK's Avatar
overfilled with oil, or bad PCV valve (change it out).
Old 03-14-2005, 06:10 PM
Default Re: Bubbles in Oil (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote">overfilled with oil, or bad PCV valve (change it out).</TD></TR></TABLE>
Correct if you have to much oil in the car then it will start to foam up.(like a dog with rabies) thus the foam has bubbles in it, which is why when you check your oil level you saw bubles. Start simple, change the PVc out,drive around check it. change oil and make sure not to overfill it to much. i usually do 4.5 just to be safe. sometimes more since im turbo. And do you have an intake?
Old 03-14-2005, 06:14 PM
StreetEG's Avatar
ya i got that fat fake j's racing in the sticky... that and worldsport are rally my only engine mods....that and a chipped p28
Ralph3991
12-05-2012 10:37 AM
95halx
09-05-2012 12:35 PM
JDM B16A
07-25-2006 07:57 PM
SkoundrelUSA
11
02-14-2006 10:06 AM
98cwitr
04-27-2004 01:34 PM
Quick Reply: Bubbles in Oil
