Bseries Axle Replacement: Drain Tranny Fluid?
Hey i am putting a new axle on my bseries swap and was wondering if i NEED to drain the dranny fluid? Its the passeneger side axle...
Thanks doin this now so the sooner i can get an answer the better
Re: Bseries Axle Replacement: Drain Tranny Fluid? (u2civic1)
When u pull the axle have the other one ready to go right in so if fluid does come out u wont lose alot. or i usually jack up the car so the fluid tilts in the other direction so when u take out the axle the fluid stays on the other side.
Re: Bseries Axle Replacement: Drain Tranny Fluid? (egvtec)
You have to make a thread about every single question you have on the same topic?
Just keep it in one thread.
No you dont have to drain it. Good idea to do a tranny flush if you havent before but not a need.
ok so i got the axle all ready to come out of the tranny but i cant seem to get it out of the actual transmission.
Im asuing prybars and all but it just aint coming out- any ideas??
the axle moves like 1/4in then seems like its stuck on something... im gonna try ahmmering it a few times but could use some suggestions...
Re: (turbotime)
Which axle are you removing?
The Driver side is in an intermediate shaft so that needs to be hammered out.
But the pass side needs a prybar or big screw driver and it should come right out.
ok- after much prying and twisting i got it out,
so i slid the new one right in and it fit perfect. Question:
should i lube up either/both end of the axle or can i just stick it in?
In the writeups i read there is no need to lube it up, just want to double check tho..
thanks again!
thanks again!
ok so i just put it in no lube...
new problem: on the tranny side, although i can push the axle flush with the tranny, if i try to pull out on the axle (like im trying to take it out, it slies prolly like 2-3mm then feels like it locks.
is this amount of play normal??
KoukiMonstr
01-11-2013 08:02 PM
