Broken camgear bolt into the camshaft help?
Old 08-08-2008, 09:44 AM
bunnyx's Avatar
Default Broken camgear bolt into the camshaft help?
will the d16z6 camshaft fit into a d16y8? will this work out. i broke my bolt in my camshaft holding the cam gear. engine head is a d16y8.
Old 08-08-2008, 12:01 PM
blk92_d16's Avatar
I've seen it done and the rear as well...just remember the difference in the two cam gears. There's what, a 8degree difference between the Z6 and the Y8?
Old 08-08-2008, 02:47 PM
itsmejto's Avatar
Default Re: Broken camgear bolt into the camshaft help? (bunnyx)
The Y8 is a better cam, I'd carefully drill it out and use an easy out to remove the broken stud.
Old 08-10-2008, 03:15 PM
bunnyx's Avatar
Default Re: Broken camgear bolt into the camshaft help? (itsmejto)
thanks for the help. yeah i was just being stupidly in a hurry and IMPACT GUN it in and broke the damn bolt.
Old 08-10-2008, 03:39 PM
1992Si's Avatar
Did you know you can turn down the power on the bottom of the grip ?
or, that's why they make air ratchets...
over on d-series.org in the top of the engine building forum is a sticky about z6/8y cam's interchanging.
egcivic
04-04-2009 06:54 AM
leighton1245
02-23-2008 09:32 AM
93-Z6-CX
08-18-2005 11:07 AM
B16aDasher
03-07-2005 04:19 PM
Soccerking3000
04-22-2004 07:14 AM
Quick Reply: Broken camgear bolt into the camshaft help?
