Brake upgrade questions (95 teg LS --> 92 hatch si)
I have a chance of upgrading my brake on the my 92 si hatch and I have a few questions. I have used the search and not much info for me even though alot about brake.
My donor car is a 95 Integra LS w/ ABS. I think the brakes are (Front is 10.3" and rear is 9.4") am I correct?
I have a 92 hatch si with 4 wheel discs now w/out ABS.
My questions
1. How big are the stock si brakes (Front and Rear).
2. What do I need to take out from the integra for the brakes swap?
3. Can I hook up ABS also if I do the brake swap?
Thanks H-T
My questions
Thanks H-T
Re: Brake upgrade questions (intezn)
2. The rears are the same as your civic, so don't even bother touching them, unless you want the lcas w/swaybar holes. For the fronts I think you have Nissin calipers, so all you'd need would be the rotors/calipers from the teg.
3. It's apparently been done but it's hard and there are no how-tos on how to do it.
Re: Brake upgrade questions (CXHatchback)
are you sure the calipers will bolt up... the offset is exactly the same from the teg knuckles w/abs to the civic w/out abs? im thinking of doing this myself but i need to be sure. thanks
Re: Brake upgrade questions (euclid)
TheHatchHog
11
07-29-2004 02:02 PM
