Brake Swap?
Brake Swap?
alright i have the rear disc brake swap off of a del sol, but i don't have the rear lower control arm the one you see from behind the car will i beable to use the one off of my 93 cx with drum brakes?
Second question i am buying steel braded lines what should i buy them for 92-95 si or 99-00 si?
Thrid should i buy brake cables for a 94-01 integra, 92-95 si, or 99-00 si i heard all would work but what will make it be like if it was from the factory the 92-95 right?
Re: Brake Swap? (mxpx035)
the lca on an integra, del sol. and civic should be the same. Most people take the whole lca off an integra and swap them on the civic. Therefore I would assume that you can use your current lca's with the disc setup. for e-brake cable, i would get the 94-01 or 92-95 si both should work and for the lines do 92-95.
Somebody please correct me if im wrong
when i did my setup i used integra LCA but either ones dont matter ! u would be fine using your Cx LCA, for the brake lines i dont know what the difference would be ! im using integra lines for mine ! all brake lines would be the same as far as i know ! thats as much help as i can give ya ! ne one else ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mxpx035 »</TD></TR><TR><TD CLASS="quote">alright i have the rear disc brake swap off of a del sol, but i don't have the rear lower control arm the one you see from behind the car will i beable to use the one off of my 93 cx with drum brakes?
Thrid should i buy brake cables for a 94-01 integra, 92-95 si, or 99-00 si i heard all would work but what will make it be like if it was from the factory the 92-95 right?</TD></TR></TABLE>
1st this **** has all been covered befor there is a HUGE thread about doing brake swaps
2nd you can use your LCA doesn't matter
3rd Ebrake cables off of a 94+ integra will work, so will any "disk brake ebrake line from a EG"
4th when are people going to learn that almost anything you need/want for your car suspension wise you can steal from a 94+ integra. the EG and DA are like soul mates
search next time
search next time
Thrid should i buy brake cables for a 94-01 integra, 92-95 si, or 99-00 si i heard all would work but what will make it be like if it was from the factory the 92-95 right?</TD></TR></TABLE> The control arms off your car will work. The integra ones are a little different but will work also. Hint integra ones should have sway bar holes.
buy integra steel lines. The ebrake cables off a 99-00 should work. If your good you can use the ones off a integra. Hope that helps. I've done seven rear swaps
Almost forgot get a alinement. Your car will thank you.
Re: Brake Swap? (94blackhatch)
well isearched and didn't find anything on lca's but thanks to the people that had something good to say.
and next time you don't have anything positive to say just shut up
2000Accord5sp
03-31-2006 12:28 PM
vtecb20coupe
07-08-2004 12:26 PM
