brake prob. need help
the brake pedal slowly eases to the floor about 1 in 4 stops. someone said its the booster but i did the check it said in the haynes manual and it seems fine? is it my master cylinder
Re: brake prob. need help
and for the obvious there is fluid, no leak, just started doing this yesterday, and i checked the lines no swelling,
the only thing thats been done so far is a valve cover gasket kit. but i just bled the brakes about three times over. it got stiffer but still sinks to the floor.
Bench bleed the new master by plugging the outlets, filling it with fluid and pumping till it gets hard. Then install it in the car.
I believe you could maybe have some air in your brake system i would recommend an bleeding sequence of all 4 lines get all the air out
before you go and replace the whole master, get yourself a new cap it could just be a problem with the gasket in the cap. Also check your vacume line to the booster maybe its dry-rotted.
Mandeep
08-17-2005 06:23 PM
