brake pedal question
Old 08-13-2011, 03:37 AM
r.etheridge's Avatar
Default brake pedal question
I have a 94 civic dx, auto with 150k on it. Everytime it gets warm, and im sitting still, (like at a red light or stop sign, anytime the brake must be applied for a extended period of time) the petal will slowly start to go down to the floor board until eventually it bottoms out on the floor board. Im not real sure why it does this, it only happens when its hot. In the mornings on the way to work it doesnt do it. I check the level of my fluid often and the level hasnt when down at all so im pretty sure I dont have a hole in any brake lines or any leaks. so im thinking I may need to bleed all the brake fluid out and put fresh in, or is it something with the brake master cylinder like a seal?
Old 08-13-2011, 03:59 AM
Resident Gearhead
BryanM.'s Avatar
Default Re: brake pedal question
Bleeding won't hurt, but it sounds like an internal master cylinder leak to me.
Old 08-13-2011, 05:05 AM
can i get like a seal kit for the master cylinder or do I have to buy a completely new master cylinder?
Old 08-13-2011, 07:43 AM
is this a rebuild kit? http://www.rockauto.com/catalog/moreinfo.php?pk=310246
Old 08-13-2011, 09:53 AM
Former User's Avatar
I haven't tried it myself, but a rebuild seems worth a try if it's much less expensive than replacing the MC. Post pictures of the rebuild if you can.
Old 08-13-2011, 04:03 PM
speedstick345's Avatar
Master cylinder seal seems bad too me. You can actually rebuild the master or buy a rebuilt one.
I rebuild one at school, not too hard.
Old 08-13-2011, 06:32 PM
I just got a used one that is a nissin reman that was only 6 months old off a totaled 93 dx for $25 so im going to try it out. A rebuild kit is around $35 shipped but it didnt look to hard to do. Thanks for everyones help
Chev
14
10-20-2017 03:32 PM
98integralsB18
Suspension & Brakes
03-08-2012 10:17 AM
Markb16a
11
08-26-2010 09:12 AM
tonezilla
12-23-2005 02:24 AM
spender1326
04-06-2004 03:28 PM
Quick Reply: brake pedal question
