Brake master cylinder question?
Can i use an integra gs-r booster with an 15/16 4dr ex master cylinder on my 94 eg? will it work? if not i do have the 1''gs-r master cylinder i'm just carious what will it do? thanks
Re: Brake master cylinder question? (drvfast)
Really? Well hell I'd definitely do it, cause the booster from the teg is supposed to be "stronger". BTW, did you bolt it up on the car or off.
Re: Brake master cylinder question? (CXHatchback)
well i bolted the master cylinder of the 4dr ex onto the gs-r booster and it fit perfect. people say the gs-r booster will bolt up to th 92-95 civics so i figured it should work fine.this stuff was off the car it wasn't on the car yet. i'm putting it on my car tommorow and i tell you how it turns out.
ok, just make sure you bolted it up right and not upside down. The mounting "ears" of the MC should bolt up to the teg booster, but upside down. Just make sure you had it right.
civicandy
07-18-2006 06:30 AM
jdmcivicferio
01-05-2003 09:23 PM
