brake booster/master cylinder question
i've got gsr front and rear brakes on my 97 lx, and will most likely be using the same bb/mc. my question is, how do i reflare my stock line? what parts are needed? also, do i use the integra prop valve, or an si? thanks
Modified by aak at 11:21 AM 5/24/2006
Re: brake booster/master cylinder question (aak)
flare? i'm not sure if you have to flare. i do you might have to rebend the line.
you need a tube bender. you a good one you'll pay about $20 at autozone.
Re: brake booster/master cylinder question (Slamaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slamaccord »</TD></TR><TR><TD CLASS="quote">Your original brake lines should thread right onto the integra master cylinder.
Correct me if I'm worng. </TD></TR></TABLE>
you're correct, you just have to bend the lines so it lines up to thread it in. autozone, sears, harbor frieght sells the pipe bender.
Re: brake booster/master cylinder question (Lord Helmet)
thanks guys, i just got through searching some more and ended up finding the info i needed . for some reason i thought this was so much harder than it really is. hope this may have helped someone.
oh yeah, which proportioning valve should i use. i've heard people say si, instead of integra. i have gsr front and rear, with bb/mc on a 97 civic lx. integra makes sense to me. also does abs have anything to do with this swap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aak »</TD></TR><TR><TD CLASS="quote">oh yeah, which proportioning valve should i use. i've heard people say si, instead of integra. i have gsr front and rear, with bb/mc on a 97 civic lx. integra makes sense to me. also does abs have anything to do with this swap?</TD></TR></TABLE>
if your car has abs, it won't have a proportioning valve(PP) on it because the abs pump in it is used in it's place.
explain how that works? how can an abs actuator distribute braking to front or rear without a prop valve? anyone else recommend the right prop valve i should use? thanks
VTECisSeXY
10-24-2003 08:37 AM
