boosted eg gsr throwing a map sensor code? Please help
I have a 94 hatchy with a boosted gsr motor in it. I've been driving it fine for about 2 weeks now, no problems but then yesterday when i was driving it home it threw a map sensor code. Now, I know that your supposed to run a check valve on boosted cars, but I'm running a S-AFC, and I thought that if your running a AFC of some sort, you don't need the check valve. Help me out guys, is this true or should I try running a check valve?
Re: boosted eg gsr throwing a map sensor code? Please help (9hatchman4)
I have 94 JDM GSr with a JR supercharger. I am also getting the map sensor code. I have checked the voltage output which is okay. I am still getting the light under hard acceleration from a stop. I am thinking of changing to a 3 bar map.
AFC does not stop the map sensor from seeing boost. You will need check valves/missing link or better yet some sort of aftermarket computer (Hondata,Crome,AEM,Uberdata)
