Blox LCA's / ASR sway bar kit do they work together?
I'm a newbie here so if this isn't the place to post please let me know.
I have a 93 civic coupe ex and I just got my blox LCA's and ASR sway bar kit. This setup doen't seem to work right with the end links that come with the kit.
I think the hole that the C-clamp goes into is to big and it isn't threaded so I'm looking to see if anyone else has this setup and how to make it work.
I called Blox and they said that it doesn't work. I would need to fab something up.
Its the circular hole here that I'm speaking on (I'm also new to cars so any help would be good).
Re: Blox LCA's / ASR sway bar kit do they work together? (dodgeball)
what endlinks are you using, you should get some heim joint endlinks
blox sells them and you can also get them from ASR, they sell Aurora endlinks
Re: Blox LCA's / ASR sway bar kit do they work together? (sicones)
I have the type R end links.
I think we need to fab something together.
Let everyone know that blox LCAs and the ASR kit with the type R sway bar DOESN'T work together.
Ek Forever y0!
blox endlinks
They're all compatible. All aftermarket lcas have a place for mounting swaybar hardware.
That's the point of aftermarket lcas.
Re: (allricedout)
So different LCAs have different sizes in the C-clamp holes? If thats the case will a Blox C-clamp work with the ASR sway bar kit?
Blox told me that they bought a ASR kit and tried to fit the kit to the LCA and they couldn't get it to work.
Am I the only one that has spoken on this?
Re: (dodgeball)
Hi,
I have installed my blox rear LCAs and I picked up a jdm type r rear sway bar and it came with end links.
I purchased all the stock hardware to install them so after reading everything above I guess I will have to buy the blox endlinks now...?
