blown headgasket....questions on damage....?
Old 07-05-2006, 08:48 PM
B18C EG2's Avatar
Location: Home Of The Players And PIMPS, IN, united states
Default blown headgasket....questions on damage....?
ok i blew my headgasket today after only putting 200 miles on my build...
sucks ***....
anyways on with the question
i blew the headgasket and to state the obvious it was apparent that the water was mixing with the oil.....i pulled the head the night i noticed it was overheating...and drained all the oil....the cylinders looked fine wiht no scoring...i put oil in the cylinders and clean em up a lil....
how do i clean all that stuff outta the oil pan and the coolant chambers?
flush it once motor is put back together?
pull oil pan?
i dono..
i planned on replacing the gasket...coolant flushing...pulling the pan and cleaning that...and just running it
need suggestions....if i need more help?
Old 07-05-2006, 09:15 PM
honda_civic1's Avatar
what I did and the easy way I think, is to get a vaccum. Then get some sort of little/skinny hose and just suck up all that cooletnt/oil/etc into the vaccum.
gl.
Old 07-05-2006, 09:22 PM
hitvtecgetloud09's Avatar
Default Re: (honda_civic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_civic1 &raquo;</TD></TR><TR><TD CLASS="quote">what I did and the easy way I think, is to get a vaccum. Then get some sort of little/skinny hose and just suck up all that cooletnt/oil/etc into the vaccum.
gl.</TD></TR></TABLE>
never though of that just.
i would just drain watt evers in the pan and dry to suck out as much as i can and once u get the car running agian i would flush out both the rad. and the motor.
how'd u blow a headgasket btw after 200mile..
good luck.
Rikaro
08-21-2008 09:48 PM
da9kid11
06-29-2008 06:36 AM
turbotime
12-22-2005 01:46 PM
Stevorh
02-22-2005 11:37 AM
civicnightmare
01-20-2004 02:15 PM
Quick Reply: blown headgasket....questions on damage....?
