block swap question
block swap question
I have a 92 civic hatch, stock obd1 motor. Can I swap an obd0 block straight over, using my stock ecu and wiring harness? Or are there things that need to be done to make it compatible with an obd1 head?
Re: block swap question
It would be just about everything compatible, just use your obd-1 stuff. i.e. intake manifold and sensors, injectors, ecu, and thermostat housing, etc...
No. The block itself has nothing to do with OBD.
Everything OBD1 is on the head. As long as you use the old one you are good to go.
spooncivic1
07-27-2006 04:57 PM
