blinker problem
blinker problem
car: 1992 civic HB
engine: 97 ls i think
Problem: for some reason the blinkers dont work. I am going to check the fuse today and see if its blown but i dont think that it is cause my borther took apart the whole dash to see if a wire was shorting or something. but never found anything. (WHERE IS THE BLINKER FUSE LOCATED IF THERE IS ONE) His hazards work. The rpm's, speedo, fuel, temp gauge also dont work. the high beam light works. The tac lights up most of the time but sometimes it doesnt come on. Is there a way i can use the hazard button in some way as a blinker so i dont get pulled over.??? What else should i check??
any help is appreciated alot!! Brother left for the marines and trying to get it fixed for him!
Re: blinker problem (Blue00Si)
Unceasing Measure
So he took apart his entire dash because his blinkers weren't working? I can only imagine that he checked the fuses first if he had the mechanical ability to take the dash out of the car.
Good luck.
Good luck.
Unceasing Measure
Re: (Blue00Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue00Si »</TD></TR><TR><TD CLASS="quote">ok if the fuse is ok what should i go about doing next</TD></TR></TABLE>
Is the switch at the base of the blinker stalk broken? Have you checked the bulbs?
the base of the blinker stick isnt broken it still locks when i move it up and down. And which blinker bulbs any specific one or both? (front and rear bulbs and inside bulbs?)
try checking the ones that aren't working... it'd be pretty rare for all 4 of them to be out at the same time, but it could happen. tried checking the turn signal flasher?
Double_Dk
05-10-2005 05:03 PM
landon
10-11-2004 04:21 PM
TecHnOCal
16
01-27-2004 06:36 AM
