black buildup on spark plug threads?
Old 10-18-2005, 11:46 AM
Civicse's Avatar
Default black buildup on spark plug threads?
I just replaced the spark plugs a week ago cause apperently the former owner never replaced them in 4 years, and i checked them today and there is a dry black buildup on the first 2 or 3 threads, contact points are still clean, the original spark plugs were white, and prolly about .06" of clearence between contact points so i'm assuming thats why they were getting so hot, could i b burning oil? oil level does look slightly lower than full, changed it about a month ago, also i noticed that if i rub my finger in my exhaust pipe at the back its all black
Old 10-18-2005, 12:12 PM
Civicse's Avatar
Default Re: black buildup on spark plug threads? (Civicse)
bump
Old 10-18-2005, 12:13 PM
xPhantomSolx's Avatar
seafoam your motor and see if that helps at all.. it's either gonna be carbon buildup or oil. Either way seafoam should help.
Old 10-18-2005, 12:19 PM
3rd g3aR vTak
. O M E G A's Avatar
Your burning oil . I'm sorry bro .
Old 10-18-2005, 12:21 PM
q45mm's Avatar
Your burning oil very slowly. (posibility)
How many miles are on the car?
Old 10-18-2005, 12:22 PM
Civicse's Avatar
Default Re: black buildup on spark plug threads? (omega02379)
shitty thats what i thought, i guess i'll go do a comp test, i doubt i need seafoam, only 111,000 km's on it,
Old 10-18-2005, 01:05 PM
alotawatts's Avatar
Sounds more like carbon to me - Dry/Black. I would bet you are tuned too rich.
I would also bet that Seafoam is not the fix.
Old 10-18-2005, 01:44 PM
Civicse's Avatar
Default Re: black buildup on spark plug threads? (alotawatts)
ya, i'm thinking its the ignition timing, just incase i'll check all sources, do a comp and leackdown test, but my money is on the ignition timing, when i had my tach in it always idled at 1000, supposed to be 750
Old 10-18-2005, 02:47 PM
Civicse's Avatar
any body have any more opinions on this before we put this thread to rest? sounds kinda of abnormal for a 2000 civic to b burning oil so early? from what i know the previous owner didn't have the oil changed regularly, i'll make sure i double check with honda though.
Old 10-18-2005, 02:52 PM
99blackcivicSi's Avatar
what motor do you have?
sounds like carbon to me, and can you post a pic? that will tell me for sure
Old 10-18-2005, 02:55 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omega02379 &raquo;</TD></TR><TR><TD CLASS="quote">Your burning oil . I'm sorry bro .</TD></TR></TABLE>
Way the helll wrong. If he was burning oil the plug would not be dry. There would be an oily sludge buildup on the plug.
He is running rich, that is all.
If you have access to any type of data logging hardware or a scan tool I would reccomend taking a look at o2 sensor data and long and short term fuel trim to see how much more fuel is being added.
Old 10-18-2005, 03:06 PM
Civicse's Avatar
Default Re: black buildup on spark plug threads? (JDM-97CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX &raquo;</TD></TR><TR><TD CLASS="quote">
If you have access to any type of data logging hardware or a scan tool I would reccomend taking a look at o2 sensor data and long and short term fuel trim to see how much more fuel is being added.</TD></TR></TABLE>
i don't have any scanning tools, should i still check my timing and adjust idle though? and as for running rich can any shop with the proper tools fix this or is this something honda has to do? thanks
Old 10-18-2005, 03:07 PM
m00nr0ck Si's Avatar
Quote, originally posted by omega02379 »
this gets my vote , There not a whole lot of cars that dont have a little of the black inside the tip of the exaust , (dry black souty crap) and to the guy that automatically said your burnin' oil , your a frickin' idiot!!!!
Old 10-18-2005, 03:08 PM
Civicse's Avatar
oh and for the black residue in my muffler tip, is that anything to worry about or just some carbon from running rich?
Old 10-18-2005, 03:17 PM
Civicse's Avatar
its a d16y7 by the way, i don't have pics but the black buildup is like baked on, doesn't come off just by brushing my finger on it,
Old 10-18-2005, 07:20 PM
.Ry
.Ry's Avatar
The black soot on your muffler is the same as whats on your plugs.
nghtshd88
03-27-2012 07:40 PM
be.twenty
05-13-2008 09:49 PM
ge_itr
12-15-2006 08:14 PM
Cractos
11-10-2004 07:47 AM
lemongreenhatch
08-14-2004 06:24 PM
Quick Reply: black buildup on spark plug threads?
