BIG brake, drill, slotted...etc...Question!
Guest
Posts: n/a
with most new rotors in big brakes or aftermarket rotors...does it matter which direction the pattern is going? cauz i wilwoods have an arrow pointing against the way the wheel is rolling. should that be right, on the wilwood diagrams it has it like that. i thought about it and it seems that the slots r there for a reason...to cool the rotor down more by air pattern? am i right? ...kind of a weird question, but it seems like an h-t type of question
Re: BIG brake, drill, slotted...etc...Question! (ek9vboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9vboi »</TD></TR><TR><TD CLASS="quote">with most new rotors in big brakes or aftermarket rotors...does it matter which direction the pattern is going? cauz i wilwoods have an arrow pointing against the way the wheel is rolling. should that be right, on the wilwood diagrams it has it like that. i thought about it and it seems that the slots r there for a reason...to cool the rotor down more by air pattern? am i right? ...kind of a weird question, but it seems like an h-t type of question</TD></TR></TABLE>
The slots are not there for cooling actually.. They are designed to carry the gasses away from the pads and allow for a full contact patch on the rotor. They are directional, I know that much. I am not sure exactly what direction they should be facing however. If you have matched it to the install diagram then I don't think you have much to worry about... Although the arrow should be pointing in the direction of rotation... Strange.
