Best spark plugs and wires
Re: Best spark plugs and wires
it just depends how you use your car. if you're just running a stock motor, the cheapest plugs are perfect. I think that the base model is the V-Power. not sure though. Wires are 8mm and I've only seen them in blue.
on a stock or semi-stock engine, use what the manufacturer calls for. honda calls for ngk so use that. the car should have a sticker under the hood somewhere that gives you a ngk part number. just get a set of those and wires and ur set.
i have a jetta so i only use bosch parts in mine.
psegs80
08-02-2005 02:34 PM
