Best clutch/flywheel replacement on a budget?
As the title states, I am looking for the best clutch and flywheel replacement for under around $200.
95 Civic with the D16Z6, completely stock. Currently the car shakes coming out of any gear, also shakes when giving light throttle at any speed without the clutch engaged and the clutch engages within the first half inch of pedal. Fluid is also contaminated with what looks like motor oil. Anyways, this is my only vehicle for work and also my daily driver. I have no real plans for adding power as this motor has over 200k on it. A few of my buddies suggested the XTD Stage 2 or Stage 3 clutch and flywheel kit on eBay for around $160 but I have read bad stuff about that brand, ESPECIALLY their stage 1 kit. I have $200 to spend when I get paid and my car is almost becoming undrivable. I just need it to be reliable and maybe a little fun to drive.
What do you guys suggest for a reliable clutch kit on a budget?
Re: Best clutch/flywheel replacement on a budget?
I want the car to be reliable mostly. I may do some cosmetic mods (does have some cancer on the quarter panel and the hood needs to be replaced), lower it a little and put some wheels on her. Just to look good and be a good daily driver.
You're not going to slap some 17in rims on there are you? Cuz, that's going to look horrible.
Tein s tech, 15in wheels. Done. Simple, mild drop.
18in chrome spinners or go home
Oh HELL no. Lol
Largest wheels I would go with would be 16s. Anything more than that makes me want to vomit.
I have been rocking a stage 3 clutch with their 8lb flywheel for the last 6000 HARD miles with only 1 issue in the beginning. The T/O bearing was noisy and continued after break in. I emailed XTD and they sent me a replacement bearing NO QUESTIONS ASKED. Done and done. This is a good kit for the price, don't just listen to all the negative. Hell, I can tell you by reading what I am sure to have been hundreds of thousands of reviews on various products that most people don't review anything unless they have a bad experience. (That's a whole other topic though).
Anywho.. XTD is great for the money. Have they had some issues? Yeah. So have comp clutch, ACT, exedy, etc. I have purchased units from those 3 that went **** up too and a buddy of mine had a fidanza flywheel self destruct on him. Lemme tell ya, flywheel ring gear is no good hurling through the air from an 8k RPM takeoff.. Like having a ******* claymore detonate in your engine bay. Thank God he didn't have a passenger..
Corvette Forum Member
+1 on the Exedy clutch and flywheel for a stock car, and another +1 for Rock Auto! I installed one in my old EH9 and loved every bit of it. However, I have "heard" that the disk springs can break from their perches, but that was from someone who regularly abuses his car...
If the clutch goes in my EJ6, that's the clutch kit I'll be installing!
P.S. Don't put that thing back together without replacing the rear main seal!
Have you tried bleeding the clutch? Using a MityVac, you can bleed the whole system in less than 5 minutes. Ya never know, you might not even need a clutch.
Rs-xtacy
10
05-18-2007 04:27 AM
beandip
11-23-2003 11:31 AM
