Bent Subframe?
Bent Subframe?
Well as said in my airbag thread my car was in an accident I was driving around april and a dog was on the road tried to go in the other lane and person by me didnt move so I hit the side curb tire poped and hit curb again so it comes down to this question is my lca bent or is it my subframe because today my car was vibrating a little while driving today and im pretty woried can anyone on here help and sorry for big image
The Grumpiest
Re: Tire Pushed Back To Fender
Have you not inspected your car since April and been driving around on that? Get under the car and look around. If you don't know what you're looking for, take it to a shop. It could be anything.
And tried to put smaller pic but didn't work and can anyone verify what it is cause I need it to last 2 more weeks like that cause from older posts its mostly lower control arm or subframe and I have a picture of the inside too if you want me to upload it
It looks like your tire is hitting the wheel arch, do you notice noise when turning hard in any direction? You car needs some serious attention, could be a danger to others as well as yourself if driven.
You wheel may want to pull into the wheel arch even more than what is in your pictures if it is rubbing.
The Grumpiest
It could be anything. Get under the car and at least TRY to look around. Take some pictures and post them. Hint; take the pictures at a lower resolution to start with.
here is another picture if this helps and there is no noise outside just a little vibration for at least 3 seconds when stopped and stops after and lastly picture is still large
Ok went underneath car cant tell some things are bent lca for a fact here are the big pics
Seagull Management
LCA and/or subframe is bent. Sometimes the subframe damage isn't easy to see. I'd replace the LCA first, if it's still bent then look at the subframe and possibly the knuckle too.
Also, the LCA needs to come from an LX/EX (maybe HX as well) basically needs to come from a '96 - '00 with front swaybay (except '99 - '00 Si, they use a different style LCA)
had the exact same thing happen to me, they replaced lower control arm and shock.every case is different but try getting a replacement lca n see if it even fits in like it should n maybe go from there....
like the guy above says, every case is different. Main causes is bent lca and crushed chasis rail (where the sub frame mounts). most alignment shops will easily identify the cause.
a chasis rail that has been pushed back will have to be pulled forward by a specialised rig
Bent Subframe
Hey again as my old thread was about what was causing my tire to be pushed to the fender I cant tell if my subframe is bent or out of place and also my lca is crushing a bushing but I dont know if its part of the control arm or its a standalone bushing but Ill post pictures now and if anyone can resize them that would be helpful thanks
